Initial Pressure Valves
Hi to all
I am the new member from Quebec....
I just want to advice you on the serial numbers on the pressure valves if you decide to install
a second set of wheel on your IS 2006.
Make shure you take the serial number on each valves and ask your Lexus dealer to enter the serial numbers on the car computer .
If they are not entered, you will not be able to initial the pressure on that set of wheel.
Also you will alway have the red warning sign on your dash, and the computer display will be stock on the pressure system error !
I learned the hard way, now you will not need to pay thice for the installation !
Begood9394
11-01-17 07:55 PM
