XenonDepot HID install help finding H11 connector
Old 12-29-05, 03:21 AM
lexus27
lexus27's Avatar
Default XenonDepot HID install help finding H11 connector
I'm planning on installing my HID kit from XenonDepot but came across a problem.
The kit has the H11 connector that's suppose to connect to the factory H11 connector to power the relay to the ballasts. I know that there is one connector inside each projector housing that I can use, but is there any other connector outside (in the engine bay) that I can use?
I spent a long time tonight looking for one with no luck.
Has anybody found it?
Thanks,
Dee
Old 12-29-05, 06:46 AM
Dabigman
Dabigman's Avatar
Same problem I had, the kit is generic and not just for the IS. There might be a better way but this is what I did:
I cut the relay lead (black and white I believe) and pushed them through two tiny holes I made in the provided grommet. So one grommet had 4 wires coming out of it. I them tucked the OEM H11 inside the light enclosure, connected it, and then shut it. Then I soldered the relay wires back together and shielded with heat-shrink tubing.
Old 12-29-05, 07:37 AM
lexus27
lexus27's Avatar
I was thinking of the same thing, but was gonna go ahead and get an extra grommet for the relay power. I'll look into just using the same grommet as you did. Thanks.
Dee
Old 12-29-05, 08:40 AM
BlackStevo
BlackStevo's Avatar
.............just one of the many reasons i'm getting a sport package, factory hid's................
Old 12-29-05, 09:19 AM
Dabigman
Dabigman's Avatar
Well the way Lexus made the packages OEM HIDs would have cost me $5000 more for things I don't want (Prem Pkg + Sport or Lux Pkg). Especially since I am going to upgrade my suspension with better aftermarket gear.
Old 12-29-05, 09:35 AM
Tropheus
Tropheus's Avatar
What I did was I yanked the black and white wire including the pins from the white female connector housing. Then I feed them though the rubber grommet (so now there are 4 wires comming out), then plug the pins back into the white connector. It's a tight seal, but I went the extra miles to put some silicone sealant on the grommet. Good luck.
07Lex350
09-30-11 09:16 PM
khoab88
GX - 1st Gen (2003-2009)
09-20-10 08:14 AM
imDementeD
SC- 1st Gen (1992-2000)
27
07-15-10 08:28 AM
RyanQ
Lighting
12-15-08 08:52 PM
GS300Rich
Lighting
97
09-21-05 10:18 AM
Quick Reply: XenonDepot HID install help finding H11 connector
