Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
#376
Congrats and enjoy! Something else to consider doing is adding a switch to connect the pink and white/silver wires, that way you can enter destinations while moving. I will do that when I get my car...
Look forward to hearing about your report when you get back from your trip this weekend. Congrats again!!!
#377
Ya, something odd must be happening with Lexcellent's connections, loose wire maybe?? Because the 2006 and 2007 should be identical, and it seems to be working for you... The nav "losing" you sometimes is a problem people who have NOT done the hack experience as well...
We'll see what happens when 350_PR tries it...
I will let you know guys as soon i finish.
Talk later..
#378
Everyone with a 2007 who has done the hack, please download these 2 video clips and report back which your nav looks like... "smooth" or "jumpy"...
These are .MP4 files that I've renamed as .AVI.
IS350_Smooth_Nav.avi
IS350_Jumpy_Nav.avi
IS350_Jumpy_Nav.avi
#379
I cant believe that everyone is just doing this mod. I willprobably do it too once my initial fear of something going wrong with the navi in the future (un-mod related). Then the stealership has a good reason not to honor the warranty.
#380
The company that offers bluetooth advice for my dealership said they can do this mod for $375. LOL The guy said it involves using some relays, etc. I wonder if that was just BS. I need to call back tomorrow and ask if it voids the warranty.
#381
im pretty sure a cl member would do it for u for a small fee whether it be food or money.
#383
uhh.. The way i did it involves relays. It is more controllable then what you guys did.
The DIY is like beginner for the Nav Hack.
The way I did it with Relays is Advanced Nav Hack.
No need to fret, you can still make it better if you did it as per this DIY. I can guide you through the process to make it better.
#384
I have a couple questions. Sorry if they're stupid, I scanned a little bit of the thread, but didn't want to search 23 pages...
1. I'm a little confused based on some of the recent replies. Does this hack not work the same on 2007 models?
2. Are there any common mishaps or malfunctions that people have experienced after they do this?
Thanks for the help.
#385
2. loose wiring connections is the only problem... make your connections properly and you should have no issues
#386
I'd much rather do it the "right way". Have you poseted what you did anywhere? I'm interested
#387
OK simple.
Parts need:
(3) 5 Prong Relays
couple feet of 18 Guage White Wire
couple feet of 18 Guage Red Wire
couple feet of 18 Guage Pink or wutever color wire... This is for the Pink Wire
Bunch of Male & Female SPade Connectors
(1) nice switch. i'll show u the link later. about $12.00.
(1) T Tap
some eletrical tape
OK. Once youget all of the parts, you need to extend the 3 wires you have cut. approx 6-10 inches
The White Wire
The Red Wire
The Pink Wire
I pretty much wired the relays like this:
--Pink Relay--
Pin 30 = Pink Wire from the Car
Pin 87A = Pink Wire to the HU
Pin 85 = Switched 12V (+)
Pin 86 = Ground
Pin 87 = To White Pin 87
--White Relay--
Pin 30 = White Wire from the Car
Pin 87A = White Wire to the HU
Pin 86 = Ground
Pin 87 = To Pink Pin 87
From Pink Relay Pin 87 to White Relay Pin 87. Connect these 2 pins together with a Wire.
--Red Relay--
Pin 30 = Red Wire from the Car
Pin 87A = Red Wire to the HU
Pin 86 = Ground
Pin 87 = Ground
When the coil is not charged (NO 12V Applied), Pin 30 and 87A will act as 1 wire.
When the coil is charged (12V Applied), Pin 30 and Pin 87A will be interupted and disconnected. Pin 30 will connect to Pin 87
DOes this make sense? Let me know.
Parts need:
(3) 5 Prong Relays
(1) T Tap
some eletrical tape
The White Wire
The Red Wire
The Pink Wire
--Pink Relay--
Pin 86 = Ground
--White Relay--
Pin 86 = Ground
--Red Relay--
Pin 86 = Ground
Pin 87 = Ground
#388
Tech Info Resource
Case in point - single spade connectors for three wires. Why? Wouldn't it make a LOT more sense to get a three or four pin polarised block connector for an inline device? Since you can get connectors and pins from Lexus, you could actually do it so it looks completely factory, and has factory reliability (assuming you own some decent crimping tools.)
I also feel very sorry for the ultimate owner of any car with a soldered wiring harness. Nothing could be more UNreliable. Wiring harnesses with solder connections are illegal on aircraft for a reason - they have a poor MTBF especially in high vibration environments - and they are extremely difficult to troubleshoot because the breaks are under the insulation at the point where the solder/flux wicked up underneath it. I know this from first hand experience on my WC-135B. You'll notice there are no connections on the OEM harness with solder on them. It's not for cost reasons.
#389
This is the #1 reason I am leary of used cars. When someone hacks the OEM harness and does not do quality work, mystery problems crop up at some point and sometimes render the vehicle inoperable. I've seen this with OEM harnesses too (I have a very long story about troubleshooting a single bad connection on the ECM connector on my Supra), but I have only rarely seen a modded wiring harness that equalled factory quality.
The block connector does sound interesting. COuld you please share in depth?
In my opinion, having the Nav Hack controlled via switch is the best. If in the event your car does need those such wires to be connected, a flip of the switch will reconnect all cut wires back to OEM... assuming the extra connections would not affect the overall feed of the signal.
I hacked mine with the switch and it does work great with more control.
#390
Originally Posted by istundra;2183***
OK simple.
Parts need:
(3) 5 Prong Relays
(1) T Tap
some eletrical tape
The White Wire
The Red Wire
The Pink Wire
--Pink Relay--
Pin 86 = Ground
--White Relay--
Pin 86 = Ground
--Red Relay--
Pin 86 = Ground
Pin 87 = Ground
Parts need:
(3) 5 Prong Relays
(1) T Tap
some eletrical tape
The White Wire
The Red Wire
The Pink Wire
--Pink Relay--
Pin 86 = Ground
--White Relay--
Pin 86 = Ground
--Red Relay--
Pin 86 = Ground
Pin 87 = Ground
do you think you can get us a picture of what this looks like? where did you put the switch and which one did you use..?
