Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
#406
Which begs the obvious question - what is the best way to secure the wire connections ? Is it better to use caps, or securely wrap w/electrical tape, or another method ??? Can members who have done this hack that have logged the most miles since chime in on this . . .
#407
"Which method of connecting wires is best for a beginner?"
The answer is proably crimping tubes. But honestly, it's best to take it to a professional shop and have them do it if you cannot make a secure connection.
#408
here the picture to have an idea:
http://www.radioshack.com/product/in...entPage=search
Good luck.
#410
Oh and everyone here says the vents are the hardest thing. All you need is a pair of needle nose pliers. Wrap them with a thin towel, rag, old t-shirt, whatever and pull the vents out, takes two seconds.
I like the DVD feature and having access to the phone is sweet!
#412
#414
I just did it by wires. The switch is a good idea but for me it wasnt worth the extra effort. I pulled the loom way back and connected the pink and white wires with an extra piece of wire using wire tube crimps. This way if something goes wrong, I can just rip off the connectors without losing any of the original wire length, reconnect and eveything will be placed back beneath the loom. In the case of the white wire the cut would be behind the nylon tape. I'm wondering if anyone knows where to buy the thin electrical tape used to tape off the ends of the loom? It's not the typical vinyl tape, it's much thinner. I'd like to be able to put everything back exactly how it was should I ever need warranty work.
#416
i think there is a lot of heat in that area so be careful with any type of connection that is heat activated or might loosen up when exposed to heat. mine came loose one and it's painful to go back in....
#417
If you know how to do this wire hack for a 2006 IS 350 with ML, I will pay you to do it. Makes me nervous! Or if you know of a professional near Los Angeles, that would work too.
brunola@aol.com
brunola@aol.com
