Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
Old 06-14-07 | 06:30 AM
  #496
carlos's Avatar
carlos
Originally Posted by peterAP2
so this is a one time thing for entering addresses or every time i want to enter an address?
Every time you start the car. Also, it won't work if you have an '07 or if you have an updated disc in your '06.
Old 06-16-07 | 12:59 PM
  #497
crash009's Avatar
crash009
This really works!! Thanks for posting. TIP: Tape off your ash tray, i scratched it up! (easy!)
Old 06-18-07 | 04:45 PM
  #498
ConradEOD's Avatar
ConradEOD
ok quick question... I have the ML nav... did everything exactly as shown. I can now watch DVD's while driving, but when I go to input a destination address while driving everything fades gray and won't let me input anything. this happened to anyone else???? Weird the DVD works while in motion but no address input... HELP!!!
Old 06-18-07 | 04:56 PM
  #499
ben_r_'s Avatar
ben_r_
This hack is not for inputing destinations when driving... thats a different one.
Old 06-22-07 | 11:44 AM
  #500
TheMirage's Avatar
TheMirage
Originally Posted by kangmin
Hi guys,
I tried this hack and it worked for a day or 2?
I did the wiring and didnt put the air vents back on at the time.
I drove around testing dvds.
It worked.
I tried a few movies from China with all region code, and it worked too.
I tried a the Matrix Triology (made in USA) and that worked too.
I put the vents back on and tried...it stopped working.
I dont specificially think its the vents, but I'm wondering whats wrong.
Any ideas?
_kevin
Umm, I didn't see anything in the wiring that indicates that this would unlock the DVD region code! I think the Chinese DVD's you tested are region free :-\
Most of my DVD's are region1 (from Amazon) and my car's player is region2 :-(
Can someone test this and reply back, please?
Mirage
Old 07-01-07 | 06:48 AM
  #501
wallyshap's Avatar
wallyshap
Is There A Proceedure For This Nav Operation For A Ls430 2006
Information Is Greatly Appreciated.
Old 07-06-07 | 12:03 AM
  #502
oblivionis's Avatar
oblivionis
I just did this hack the other day. I had no problems at all and it is working great.
Old 07-07-07 | 03:00 PM
  #503
shapam's Avatar
shapam
Hello guys
I'm really looking for a help
I have done this "mod"
For now there is a big problem for me
When headlight is in "auto" mode - every time when I'm switching off the engine - headlights and backlights are staying "on" )
This is really a problem for me
Even after returning everything back - the problem is not gone
I have checked every connector in the dash many times - nothing help.
Please, may be someone give me an advise? It is very costly to go to the official service centre in UK
Old 07-11-07 | 12:00 AM
  #504
andreys's Avatar
andreys
Originally Posted by tsai3904
Would this work on the 07 RX 350? I know the 06 IS and the 07 RX have the Gen 5 navigation but are the wirings the same?
Has anyone done this on RX330 yet? Not sure how to take Nav unit out...
Thanks,
-- Andrey
Old 07-11-07 | 12:42 AM
  #505
oblivionis's Avatar
oblivionis
Originally Posted by shapam
Hello guys
After switching off the engine the lights usually stay on for 30 seconds. This option is normal but can be turned off. The navi mod itself should not affect the lights; especially since you put everything back together.
Old 07-11-07 | 01:30 AM
  #506
IS_NIICE's Avatar
IS_NIICE
okay try togglin the "DOOR" switch near the dome light. the other day i was playing around with that button and when i locked my car pressed, the lock button on the remote 5x the lights still didnt go out. i opened the car hit the "DOOR" button, then tried locking it again. viola. lights out.
Old 07-11-07 | 02:28 AM
  #507
oblivionis's Avatar
oblivionis
We were talking about headlights.
Old 07-11-07 | 03:02 AM
  #508
IS_NIICE's Avatar
IS_NIICE
i know. when i pressed lock when my door button was OFF. the headlights would not turn off regardless of how many times i pressed the locked key. when i turned it back to ON, the headlights would go off after i pressed it 2x.
Old 07-31-07 | 08:23 AM
  #509
CT250's Avatar
CT250
[QUOTE=Payam;1650425]To enter addresses while driving, you don't have to cut or splice any wires. You can select the overide button by going into the volume menu then:
touching the top left corner
bottom left corner
top left corner
bottom left corner
then hold the override button for 5 seconds.
The reason for the wore cutting is so that you can use all of the other functions of the nav system while you are moving. For example: dial a phone number, look at folders or song titles on your cd's and stuff like that.[/QUOTE
Im having a problem with this trick. I have a 2007 IS250 and I tried the top left, etc from the volume screen and nothing happens. Am I missing something?
Old 07-31-07 | 12:43 PM
  #510
Technique's Avatar
Technique
CL Folding 500000
bottom left corner
top left corner
bottom left corner
It doesn't work with the V6.1 (2007) DVD Nav disc.
Quick Reply: Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
