Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
#616
by doing this hack and if i bought a sl2vi on my non ml nav will i be able to watch videos on the fly off my ipod??? and do i need to ground the red wire? that ml nav owners need to ground ...
#617
DO you guys know if this works on the 2008 IS 250's, because i found the hack for the olderones to go thorogh the internal system and just turn it off without cutting wires, but it doesnt work on my car.
#618
This mod won't let u access the destination menu.. for that there's a way to override without cutting anything. I borrow this from another thread:
Press Menu
Press Volume
Press the Top Left Corner
Press the Bottom Left Corner (there is nothing there)
A new menu screen will come up
Press and hold Override for 5 seconds or until you hear a beep
You will need to do this again after turn off the engine the next time u need to override again.
Press Menu
Press Volume
Only problem is it doesnt work on the 2008's...sorry if someone has asked already, but does anyone have a way to unlock those?
#619
I just pried the vents out with my hands! Well, after fiddling with the clip on the right side of the vent and the one also to the second to the right. Then I took my fingers and pulled it from the right side crease in between the vent itself and the dashboard.
Go figure.
But I am still too scared to do the nav hack cutting and such.
Go figure.
#620
Any info if i need to ground the wire to get videos off my ipod? and if so how do you ground the red wire in the p50
#621
Do you know if for 2008 they changed something? I have an IS-F and did the mod and the DVD works fine but its still graying out the icons when in motion. Anyone know? Pretty positive I got all the wires right. thanks!
#622
If you want the destination while moving you will need to use an old firmware or install a switch that kills the speed sensor.
#623
So, to enable playback of the DVD (via Sl2vi) I need to ground the red wire (parking brake) in my non-ml?
How do you 'ground' it...I have no clue what that entails.
Right now I am able to view the phonebook, mp3, and input addresses while moving with the switch, but not able to watch videos in motion.
#624
What I do is cut the wire, and then ground the PLUG SIDE of the red wire by loosening one of the screws of the metal nav cage and tucking the end of the wire underneath it, then tightening it again... That way, the nav unit thinks the parking brake is always on...
#625
To ground the red wire, cut it, and attach one end to the metal frame holding the nav unit in place...
#626
I was just going to post about this...I did the nav hack for this member last weekend but didnt know he was able to play DVD with out the ML...so is it the same red wire as with the ML DVD?? I told him to hold off and wait before he cut it or I meet him back up again to finish that last part. he has the vaistech sl2vi so I was thinking that I need to find/figure out what the ground wire is for that and ground it to the metal brackets around the navi?? I am open as its not my car so I dont want to F something up!
#627
when you say plug side do you mean the wire coming from the nav plug or the wire coming from the car...srry if this seems to redundant but i want to make sure.. and i tired a search alrdy for this... a pic would be nice of a ground red wire...
#628
Plug side means wire coming from the nav plug... That way the nav unit thinks the wire is grounded... Do NOT ground the side coming from the car, lol...
#629
The red wire that you need to cut looks more like a dark pink to me,...and the reason why I was so scared to cut it, but I just went for it, and it worked. I grounded the reddish pink wire to the unit itself in between the metal cage because I didn't cut enough of the wire to get it to the screw itself.
