Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
Old 05-16-11, 10:21 PM
  #871
ohiois350
ohiois350's Avatar
Originally Posted by stasis3131
yeah same thing i was thinking ... i knew i did the hack right. the only thing i did do is unhook the battery and then this happened. i am gonna try to find someone with a disk or something to see if that works. i believe i have the latest nav disc but like you said something might have went wrong. i am thinking of trying the dealer and seeing if they are nice enough to try a disc for me. i left the clock off so i can get to it easily .
Ok now you have the disk is out, and disconnect the battery for few mins, then reconnect them, then turn on the car, and then insert the disk, while the disk upload do not turn off the car, try this way to see what happen
Ps: what disk version do you current have?
Old 05-16-11, 10:41 PM
  #872
stasis3131
stasis3131's Avatar
i believe the disk said 10.1 on it
Old 05-21-11, 11:00 PM
  #873
ekrispin
ekrispin's Avatar
Just bought a 2011 IS250 FSPORT w/ NAV will this hack work for me?
Old 05-23-11, 01:26 AM
  #874
10lexISR6
10lexISR6's Avatar
I still have no response to the 2010 nav hack or the iPod integration with nav hack bypass. Any takers???
Old 05-23-11, 04:57 AM
  #875
CCJ22
CCJ22's Avatar
I know nothing of the 2010's. But I do know there is a thread for those that own the $400 piece of aftermarket equipment you speak of and they praise it.
Old 05-23-11, 06:15 AM
  #876
Supernin
Supernin's Avatar
hey i just tried this mod and my nav seems to be disabled. i get this screen when i turn it on and i even put the wires back to the way they were and i still get this screen. everything else seems to work ok. can anyone tell me what i did wrong
I'd check every single fuse in all 3 panels and see if any are blown. Also try rebooting it by removing the battery terminal and reinstalling. Same with the disc. If that doesn't work, get back in there and double check that you didn't pull any wires out of the connectors by accident, or accidentally cut one of them.
Old 05-29-11, 11:01 PM
  #877
IS350FAN
IS350FAN's Avatar
I had someone do that same mod for my car. I don't have ML. Mine's a 2009. I'm able to play movies or videos from my iphone or ipod while driving. It works great.
Old 05-30-11, 06:56 AM
  #878
10lexISR6
10lexISR6's Avatar
Did you buy that $400 iPod integration device to make yours happen? The 09 should be the same as 10's as far as I know. I don't have ML either. Who did it? In So Cal?
Old 06-02-11, 02:03 PM
  #879
DaveC
DaveC's Avatar
Will this mod work with a 2007 IS 350 with ML setup?
Old 06-02-11, 02:08 PM
  #880
pfdaxe
pfdaxe's Avatar
Yep. If you have a few hours....read through the thread.
Old 06-06-11, 04:33 PM
  #881
DaveC
DaveC's Avatar
Seems I was reading for ever and never saw the 2007 year specified. I was told that 2007 was a year that could be hacked.
Old 06-06-11, 04:37 PM
  #882
ohiois350
ohiois350's Avatar
Yeah I did my car and it 07 with ML, the hardest part is to take out the center vent, but it worth to hack now I can watch movie or view the mp3 track while the car in moving.
Old 07-02-11, 11:51 AM
  #883
xnfsx
xnfsx's Avatar
so for this, i would have to ground the e-brake wire and cute the white/silver and pink wire then connect them for my sl2vi to work (dvd in motion). I have an is250 w/o ML.
Old 07-25-11, 08:24 PM
  #884
stasis3131
stasis3131's Avatar
I have checked behind the radio 5x to see if I pulled something and I get nothing . I ran thru all the fuses and they all look fine to me so I just gave up
Old 07-26-11, 04:07 AM
  #885
Technique
Technique's Avatar
The only time I have ever seen that message is when the disc is bad. Do you have an original disc? You need to try someone else's working disc. You pull the battery or TV fuse, then put the new disc in, then plug the battery or fuse back in. It should load the firmware and boot up.
Quick Reply: Navigation Hack DIY Part One - Enable DVD, Phonebook & MP3 Folder While Moving
