Oem Hid
Hi, can someone with OEM HID post a picture of their light pattern? I want to compare it to that of aftermarket HID in the stock halogen projector. I wonder if Lexus would use the same projector for both halogen and HID?? But then of course they shouldn't and wouldn't. Thanks in advance.
Tropheus,
I also have the same "uneven" beam on my aftermarket HID install. Each beam is uneven.
They each look like they are notched on one end. You're probably familiar with the following picture. I tried adjusting the level (up/down) on each, but it remained uneven. It seems to me there is a piece of metal or plastic that blocks the top portion of the beam. In a way it makes sense to have it there as a projected light will be somewhat circular. That's why in bi-xenon applications, they use a baffle to block the top of the beam for low beam operation and move the baffle out of the way for high beam operation. With just the halogen, it probably wasn't bright enough for us to notice the uneveness of each beam, unlike with our bright HID's.
![](http://members.***.net/abukenos/hid2.jpg)
Originally Posted by lexus27
Tropheus,
Just for experimentation sake I took out my XD HID yesterday and put the stock halogen bulbs back in. Guess what, the driver side clip IS there. It's just less noticable due to the lower light outut. Something that I totally didn't notice before I installed the HID. That's why I was wondering if Lexus uses the same halogen projectors for HID....
Anyone with stock HID care to post some pictures of your light pattern?
I'm now thinking of pursuing the OEM retrofit route. Although the aftermarket HID look quite decent inside the stock halogen projectors, I just can't get over the "clipped" driver side beam.
Ok. Back on topic. Can someone confirm the original question?
I'd really like to know if the same projector is used in the OEM HID and the halogen.
OKOK.
It is called a "STEP" for the uneven beam pattern you guys are talking about. For LHD cars, the Step goes to the right. For RHD, the Step goes to the left.
As for are the projectors the same between Halogen and OEM HID?
Very differant. OEM HID's are Bi-Xenon Projectors. Meaning as, The sheild that creates the STEP flips down and allows the full amount of light to be released for creating the High Beam.
The OEM HID's have two sets of High Beams.
1. 9005
2. From the Bi-Xenon projector.
The bowl of the OEM HID's are much differant as well. I do not have two of them to compare side by side, but i am certain there is a differance.
From comparing the CTR Honda Halogen Projector with the CTR HID Projector, the only differance is the Projector Bowl and Sheild.
I assume the differance from the Halogen and HID version would differ as well for the IS.
Please also note that the New IS utilizes D4S system which is much brighter then the AFTERMARKET D2S systems many have installed into their Halogen Version IS.
The D4S System produces Higher Kelvins (Rated at 4800K for OE Philips) and is estimated to produce 3400-3600 Lumens.
The previous versions of the D2S System produces decent kelvins (Rated at 4200K for OE Philips) and is estimated to produce 3200 Lumens.
For the D2S Systems, the higher the Kelvins, the bluer the color, hence weaker output. For all of you that have installed 6000K HID Xenon Systems, you are producing 2800 Lumens.
When you compare your 6000K to the D4S 4800K, you are at 600-800 Lumens at weaker then OE IS HID.
1. 9005
Here is my Aftermarket HID I turn on the low beam and foglights (both HID) 8000k... After I heard istundra I think I am going to change it to 5000k for low beam and 3000k(yellow) for the foglight later when anyone of those 8000k breaks
ISBB,
In addition to the OEM D4S Bi-Xenon Projectors, I have added 4200K HID Xenon Bulbs. The output is matches great. I will update this thread once i get pictures.
For the 4200K HID Kit, I used OEM Matsu****a D2S/D2R Ballast w/ Halogen2HID 9006 D2S HID Xenon Bulbs.
According to the JDM HID Foglamp option we have seen resale for 1400 USD, those are also OEM Matsu****a D2S Systems w/ Philips Bulbs.
I chose this route becuase I wanted OEM HID Equipment (Bulbs & Ballast) at a fraction of the 1400 JDM HID Foglamp option (Foglamps, Bulbs & Ballast)
