which provider and which phone work with the 2006 IS?
I have ordered my IS and have followed the Lets Talk chart for my area. It use to have both T-Mobile phones and Cingular. Now just Cingular. Is this a sales thing? Why no Verizon? Any thoughts apreciated
to Cingular just to have it linked to my car...
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Originally Posted by dennis250
I was under the impression that your phone just had to be bluetooth. No?
Cingular & Tmobile are going to have the most phone models with bluetooth as they are both GSM providers and have had many bluetooth phones in there lineup for awhile now. Verizon and Sprint are just starting to get into the bluetooth game therfor only select models have it...
Super Moderator
I have Verizon with the new Motorola Razr, and it works perfectly. Well, perfectly with one exception- you can't transfer the phonebook to the car. Some folks over at the Toyota Prius "Priuschat" forum have figured out a workaround where you can transfer the phonebook from the phone to a bluetooth enabled laptop, and then transfer it from the laptop to the car. This should work with our cars too, since both have a Denso handsfree system. But by the time I found about the workaround, I'd already re-entered my phonebook on the car's touchscreen, which unless you have a huge number of entries, is not that big of a hassle.
P.S.
I've also paired the LG VX8100 and Motorola E815 with the car. Again, with the exeption of the phonebook transfer, no problems.
P.S.
P.S.
P.S.
That's great to hear, I love the Razr, and never thought it'd be avaiable for
Verizon, up until a few fews ago, now that you say it works in our IS350, i'M def getting it!
Verizon, for Get-It-Now contract purposes, disables the file transfer (in this case, the phonebook) feature on their phones. However, using a USB bluetooth adapter, you can change this so you'll be able to transfer the phonebook to the car.
If you don't like the idea of slightly modifying your phone (with a tutorial), then you'll have to dial manually
Super Moderator
Bichon, would you please provide a link to the piruschat on where they are transferring entire phone books from computer to car. I too am using a RAZR V3c along with an SCH-i730. Thank You.
I think this link would benefit many and save all from the tedious task of entering each name and number.
Cheers!
Cheers!
I always get OBEX and OPP mixed up
Is there an OPP profile to open on the V3C?
Er yeah I meant enter it, not dial it
You don't need to dial manually. No reason you can't re-enter your phonebook into the car. With the touchscreen keyboard on the car, it goes pretty quickly.
Super Moderator
Wait, so, with the IS bluetooth, you can enter the phonebook without transfering from the phone? In our 06' RX330 we just purchased the only way to enter a phonebook is to transfer from a phone.
Also, can you dial while driving? With the RX, of course we can't do that.
Is there any voice dial, e.g. say "call george" - this was excellent in the Acura TL and RL.
I assume without doing the nav mod (cutting the VSS wire to the nav) you can't use the phonebook while driving like the RX, is this correct?
Impatiently waiting for my IS350
Originally Posted by JMgs300
I work for Cingular and most times it doesnt matter which provider you use... your model phone just needs to have bluetooth built-in.
the other posts here pretty much have the answer. i've never talked to the guys over at the website so I have no idea what it takes to get listed. maybe they wait for you to send them a phone and they list it if it works. nobody here knows the answer.
as i said in another post, the chart show what DOES work. it doesn't list what DOESN'T work and the list is not all inclusive.
i could get into the long story about bt and compatibility with cars, but not for this forum. you basically get what you get at this point.
