Service specs for the DIY'er
I realize that most Lexus owners either don't know an oil filter from an air filter, or can't be bothered.
But I've always done all my own maintenance on my cars, mainly due to not having any money when growing up, but now more due to the fact that I can do the work better, faster and without screwing anything up the way the dealers always seem to do. I'm a perfectionist, what can I say, and that means if I want it done right, I do it myself.
So when I get my IS350, I expect to continue doing all my maintenance. Since the new IS has a lot of great things like a timing chain (rather than a belt), hydraulic lifters (rather than spring operated valves), 100k mile coolant, a sealed transmission unit, etc., I'm immediately feeling happy because I won't ever need to change a timing belt or adjust the valves (anyone who's ever done valves on an S2000, or actually just about anything for that matter, will know that as you get older your back just doesn't want to cooperate).
I'm sure there's some other Lexus-owning soul out there who likes to get under their car. For the forseeable future, the only piece of information I'm really looking for is, what's the torque spec for the IS350 oil drain bolt?
And just an FYI for you folks... most standard maintenance (i.e. oil changes, brakes, brake fluid flush, air filter, etc) are incredibly simple jobs if you've got the right tools. I've been wrenching on cars for most of my life (I'm 30), so if anyone in the N. VA area wants to swing out to scenic Linden, VA and get their regular maintenance done for a few pence and the cost of parts, and better yet learn how to do the work themselves in the process, let me know. There are also some great wineries in the area
It bugs me to no end how much dealers charge for work that's easy to do and takes little time.
I wasn't talking about warranty work. Depending on the problem, it obviously makes a lot more sense to get the dealer to do it for free in most cases.
However, some warranty issues hardly necessitate a trip to the dealer if you've got half a brain. Subaru recently issued a recall for a bolt on front seat rail. They replace it with a new bolt of equal lengh to the old, the only change being some loctite. I managed to take care of that myself with about $1.50 in parts and 60 seconds of work.
Anyway, my post was obviously a little long winded... I'm just boggled by what people are paying Lexus to do regular service.
I'm really only looking for torque specs for the oil drain bolt.
Super Moderator
I've been changing the oil on my cars since I got my first one in 1960. (can I be that old? Yup.)
I have not ever used a torque wrench on the drain bolt. I have not ever had a problem. Does that mean that on the first DIY oil change on the new IS someone will somehow screw up putting the drain plug back in correctly? As in "shoulda used a torque wrench". Not sure. Odds are all will be OK. Just use the common sense we all seem to have and do not cross thread it and tighten it till its tight and then STOP. We know when that is. A true car guy can "just tell".
I'll be doing all my own work as well, except for (of course) the warranty work. Although I'm in my sixties now I still love to crawl under my cars periodically and see what's what. Wish I was closer to the East coast. We could do this stuff together. Would be fun.
Now if my car will just show up!! They say next week or so. We'll see.
Super Moderator
Super Moderator
Look, I understand that it's simply something you can do by feel. But that doesn't negate the fact that I'd like to know the factory torque spec.
I usually do my oil changes at home also. Haven't even had the chance to look underneath my IS yet. BTW, what is a cartridge oil filter? I'm also trying to buy oil filters online but haven't found any ones specific to the new IS yet. Is the same filter used for another car? Say the GS300? Thanks.
Rather than a spin on filter that you usually find, a cartridge filter is just the filter media (what you'd see if you took the outer metal cover off a "normal" filter) that sits inside a housing. You take the cover off the housing and replace the filter that way. BMW uses the same setup.
You can get filters here:
http://www.lexus-parts.com/
... or just run down to your local dealer.
Oil pan drain plug x No. 2 oil pan sub-assembly 30 ft.*lbf
I was interested to find out from your post that the 350 has a timing chain , not a belt. Does it really never have to be changed for the life of the vehicle? Tell me it ain't so.
I'm assuming that this is the drain plug.... I know I've seen other posts around on changing oil (one new one last night on my.is) that reference the torque for that bolt. Hope this helps.
Originally Posted by Bichon
Ah, so then the IS probably isn't the first cartridge oil filter you've changed? Hopefully changing a cartridge filter isn't as messy as I've imagined.
Just got a phone call that my car is IN and would I please come and PICK IT UP!!!! So......I'm outta here.
Oh, one more thing, I DO understand wanting the torque number. Looks like it's now in this thread.
BYE.
Awesome! Post pics when it's in and enjoy.
And thx ahohnstein for the torque spec!
Good to have... I should be putting the order in for my car in the next week or so!!!
