Oh no- check engine light and check VSC
#46
Originally Posted by linh811
OK I guess it's my turn, odo JUST turned 1000 miles....
Check engine and VSC lights came on today. The car stalled out AT LEAST 10 times!! Thank god I was in my driveway. It would start and idle for a second or 2 then die. It did this like 10 times then finally stayed running. Anyway the lights are still on. If I have time I'll bring it by the dealer tomorrow.
Lexus needs to seriously get a fix for this. That is dangerous and someone can get killed if a car stalls at the wrong time!
#47
Damn this seemed more like a 250 problem, please let us know what the dealer has to say.
#48
The car started right up this morning, the check engine light and VSC lights are now off. The dealer didn't have any appointments available today but I made one for tomorrow. I"ll post what they find but have this weird feeling that they won't find anything since all the lights are off.
#51
#52
I have a IS350 with 1,550 miles.Three warning lights came on this week.
1.Engine check light.
2.VSC-on display screen between the speedo & tach.
3.Traction control light.
The tech said it was a cracked oxygen sensor # 89467-30010 and Its starting to look more like a common problem with the IS350.
Here is the message on my invoice. Concern check light is on. (SOP Sensor ) Mil on.
DTC P0158 B2 S2 02 Sensor rich. Found B2 S1 02 Sensor biased lean causing DTC to set . Replaced Sensor, cleared DTC and road tested. They replaced it today every thing is ok
The service dept asked me if it was running rough and it wasn't so i drove it to the dealer. The car never died or ran rough but if it did I would use my Lexus road side assistance to have it towed at no cost. I checked my oil seem to be ok but I will change it just to be safe.
#53
#56
Update.
Just back from the dealer. Service guy said it was a "faulty injector." He said they had to order the part, but I'm OK to drive it for now. I have an appointment to bring it in next Wednesday to have it replaced.
#57
Hmm, are you sure you guys didn't buy German? I have to giggle just a little given the fact the "reliability" thing is thrown out every time there is a discussion of the German competition.
At least it sounds like a consistent problem which means there is likely a fix. The issue with lots of newer cars is getting the corrected part made and shipped in time. What is not good is that there a significant effect on the air/fuel mixture which can, in some circumstances, cause engine damage (detonation, etc.).
#58
#59
Well, my check engine, and check VSC light came on again...gotta bring it to the dealership on Monday...... If I have raw fuel in my oil again, wouldn't it be bad to be driving around for days like that ?????
Mike
Mike
#60
Found this posted on my.is. Don't flame me if this is against the rules or something. Just trying to help you guys out. I believe this has to do with the fuel in the oil issue....
http://my.is/forums/showthread.php?t=289588
