IS350Sport-Pulling to Right
So my wife brought her car into lexus for 1 month service -We've actually had the car for almost 2 months - the car had a couple of probs: pulls to the right, front spoiler not installed correctly. The service guy calls and says he wants to keep the car until Thursday so they can order a set of tires that may fix the problem (Directional vs Unidirectional). The tires he wants to order are Bridgestone tires. The guy said (TO ME) he looked at everything that could cause the car to pull, its' not alignment, it's not steering, it could only be tires.
Does anyone know if these tires are good? All I know is that they're Bridgestone tires. Do you you think this will correct the pulling problem?
We're probably gonna pick up the car tonight and bring it back when the tires come in even though they gave us a loaner; my wife doesn't feel like driving a camry around.
On a side note: a friend that I called at Lexus was told by the same tech that the problem with some IS 350s pulling to the right has been addressed by Lexus and they've come up with a "fix". I hope my friend heard wrong - how the heck I'm I suppose to trust the tech now?
Hmmm, at lexus are you only allowed to order Bridgestones and Dunlops?
If not, try to get some Michelin Pilot Sport AS tires. IMO, those tires are awesome. They weigh about 5lbs less per tire, have 400 treadwear, and are all seasons. I have them on my 3000 and love them.
Though the forward grip may not be as good.
OR you can get the Michelin Pilot Sports, These are summer tires, The treadwear is only 220.
all manifacture tires will have problem sometime. tell the dealer to flip the front tire and see if the car pull to the other side. if it pulls to the other side means the tire maybe defect. they should replace it since you have so little mileage on it. if the car still pulls to the right after flip the tires, you should tell them to check the alignment for your car.
make sure they check airpressure before doing the alignment.
Sorry, but "Bridgeston tires" gives me absolutely nothing to go on. It depends entirely on what type they are. That being said, if he's putting unidirectional tires on it, it sounds like they're not a high-performance tires. Which may indeed fix what you think is the pulling issue, but it isn't going to handle like it does with Z rated rubber on it.
side note: I noticed on the service order that the advisor special ordered 2 Bracket Sub-Assemblies. I wonder what the heck that is all about. The parts are 63.96 each (Lexus is paying). I somehow think this is related to the car drifting.
Originally Posted by mofogasm
they start giving out rental cars after all of their loaners are gone. I had to drive a camry from hertz once
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Cheers,
Kermee
I just replaced the stock Dunlops on our IS350 Sport with a set of Continental all seasons and like them a lot. Our weather sucks bad enough the the Dunlops were no so good in the heavy rain. The Conti's are also much quieter. The Dunlops had a lot of road noise.
Regarding your Bridestone's find out what model of tire they want to install. With that info hop on to www.tirerack.com and read the reviews about that particular tire.
I agree our stock 18" dunlops are extremely noisy, and i haven't
took any hard turns yet, but i suspect they don't corner too well either..
I've been using mich pilot sports before this and found them to be
a awesome tire.. I put 20k on them and they had about 50% tread left and
were relatively quiet..
Once i put about 10-15k miles on these tires, off they go... I hear
the bridgestone pole positon so2's are great tires, (if they still make them that is)..
We changed the tires to Bridgestone Potenza RE050, added camber adjustment pieces and did a re-align. Seems to have fixed the problem. Will let you all know the final results after a couple of weeks.
Johnhav430
07-06-17 09:10 AM
