Climate Control Concerns
When I'm in 1 of 2 if the IS350's auto settings, the fan speed doesn't change at all, no matter HOW much I change the temp? Is this normal? In my ES300, if I put the climate control on auto, and turned the temp dramatically different than the current temp, the system would automatically increase or decrease the fan speed, as needed? Truth be told I like it when the system decides when the fan speed is ready to be turned up or down, based on air temp? Anyone else notice this issue?
Depends. If I've just started the car up and the the cabin temperature is below the set temperature on the climate controls, no matter how high the temperature is set including "HI", the fan speed won't change...... until the car/heater warms up.
That's the only time I've noticed the fan speed doesn't change.
Cheers,
Kermee
Cheers,
Kermee
Super Moderator
My experience is the same as Kermee's. When the engine is cold, the fan is initially off and gradually increases as the engine warms up. Once the engine is warm, the fan speed varies based on the difference between cabin temp and set point.
One other thing I've noticed: under high demand/warm engine, fan speed is one tick below maximum when the car is under way, and speeds up to maximum the car is stopped. I suppose this is to take advantage of the "ram air" effect.
I've NEVER seen my fan speed change. Perhaps it's because even though I keep the climate in "auto" I turn the A/C off. Do any of you keep A/C on in auto mode?
Cheers,
Kermee
Cheers,
Kermee
Since we are in winter, I usually keep it in auto mode and shut the AC off when I start the car. The fan speed will ramp up and down to maintain the setpoint (usually between 70 and 72 degrees)
My main goal here is never having to adjust the fan, rather adjust the temp... but both auto modes don't seem to offer this.
Again, I typicaly turn off the A/C in auto mode, since it seems foolish to use when it's freezing out, but I wonder if that is messing with the way the auto climate control works!?
Originally Posted by ES3
WHen you say the fan speed ramps up... do you know this by the display, or just the noise of the fan. I ask because on my nav display the fan speed NEVER changes from where I left it, EVEN in auto mode. I sometimes hear the fan a little more than others, but shouldn't the display move with the fan, to show what the speed is?
Both...I don't have the nav, but the fan display (number of bars) go up and down as the fan ramps up and down...and I can hear the change audibly as well....and I always turn the A/C off.
Thanks! Sounds like the issue MAY be related to the nav!?
Calling anyone else with nav! Same questions, do you notice the fan speed on the readout actually changes, when you ONLY change the temperature? In other words, can you get the fan speed to change without touching any of the fan control buttons!?
Super Moderator
Originally Posted by Bichon
I have the navi, and I see the speed on the readout change. When I first start the car and the engine is cold, none of the blue boxes are highlighted. Then as the engine warms up, first the lowest one comes on, then it moves to the second one, and so forth over to the right. Eventually, as the cabin warms, it starts moving back to the left.
Cheers,
Kermee
