LoJacK on IS350??
Isn't LoJack (minus the early warning) basically a ripoff if you have NAV? They both use GPS.
Early warning only works if people don't leave the transmitter in the car
Liquid Bra Champion
Early warning only works if people don't leave the transmitter in the car![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
So how is LoJack beneficial with a NAV/GPS that uses your current location to determine information? It's entirely probably that you are more knowledgeable that I on that score.
However," Early warning" has a transmitter that should be in "x" distance from the ignition when the car is started. If it is not in range, you can get called/emailed/beeped at various locations. So if someone left the transmitter say in the glove compartment, and the car was subsequently stolen, I fail to see how the LoJack would detect the theft.
Enlighten me.
Enlighten me.
Enlighten me.
Enlighten me.
Factory NAV/GPS in most vehicles are one-way devices only. (Someone correct me if I'm wrong but I'm sure factory OnStar is two-way and is typically the only exception to the rule). LoJack is a two-way device. Sure your factory NAV/GPS knows exactly where your car is but since it's only a one-way device, it has no way of transmitting to the authorities or to you where the vehicle is.
Cheers,
Kermee
EDIT - Added URL to LoJack FAQ's including FAQ to EARLY WARNING:
LoJack FAQ's
Personally, I don't think that my IS will ever be stolen while i'm not in it. I feel that while the probability that I'll ever be car jacked in my life is low, it would be the only thing that would separate me from my IS.
Now, LoJack is great and all if the police have the time to deal with your stolen car. Basically, it activates then you hope that there's a patrol that both has the LoJack locator equipment, and that has the time to deal with tracking down your stolen car.
Personally, I'm going to have Mobile Guardian installed.
http://www.mymobileguardian.com/
I hear that it costs almost the same, and it doesn't require the police equipment to locate your car. (Although, I'd recommend that you call the police and guide them to the location).
-Brian
-Brian
Liquid Bra Champion
I noticed whenever I take the smart key out of the car with the engine running, and I shut the door, I hear 3 beeps and the exclamation point warning symbol blinks. (I sometimes do this when I carry my set of keys out of the car so I can open the mailbox). So I'm wondering if in the off chance someone opens the door, darts into my car and attempts to drive off, will it actually go (i.e., will the transmission shift into drive? Will the throttle work? etc) Or is there some safety/anti-theft system integrated such that the smart key must be back inside the "cockpit" to drive. On the other hand, if I leave the door open and take the smart key outside the car, I don't hear the 3 beeps or see the exclamation point blinking. Wonder if THAT would make any difference in the driveability of the car in the absence of the smart key.
I know, I know, I could probably get a friend to help me "experiment" ... but on the other hand I'm concerned about causing more trouble/complications than it's worth to find out.
Originally Posted by SportyStar
Speaking of carjacking, brings to mind a couple questions. As we know, the Smart Key is required to start the car. Let's say I get carjacked, but I have the key in my pocket. I get forced out of my car. The carjacker takes off, unaware of the IS350's smart key/sensor system. Question #1, is the smart key required (to be inside the car) for it to keep on going?
If so, how far will it go before the system realizes the key is no longer in the car? Obviously, if the carjacker were to push the ignition button and shut off the engine, it will not start again in the absence of the smart key.
I know, I know, I could probably get a friend to help me "experiment" ... but on the other hand I'm concerned about causing more trouble/complications than it's worth to find out. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Cheers,
Kermee
Originally Posted by Kermee
Hope you trust your "friend" if you experiment. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Thank you for answering my questions, Kermee.
-Brian
-Brian
Just a warning, there is a door lock to pick on the IS to get inside the vehicle. Go through your manual.
Some poor CL member had his car broken into when they removed the cover and jammed it open. When it's jammed open, all the windows and the moonroof fully open. The thieves knew what they were doing.
Cheers,
Kermee
Cheers,
Kermee
If these losers would spend some time on something constructive they would probably sleep better and make more money. Crooks are smart, just lazy.
Originally Posted by bagwell
looks pretty good....same price?????
Seems like Mobile Guardian has enough functionality that I'd be comfortable paying for it...
-Brian
bhvrdr
12-18-16 12:26 PM
