Aftermarket Wheel Owners Post Your Setup
#2284
#2285
IS Year/Model: 2009 IS250 RWD
Wheel Brand: TSW
Wheel Model: Strip
Wheel Size Front: 19x8
Wheel Size Rear: 19x9.5
Wheel Finish: Gunmetal
Lip size front (if applicable): 1.5in
Lip size rear (if applicable): 3in
Lip finish (if applicable): machined
Offset Front: +40
Offset Rear: +45(running a 5mm spacer to make it +40)
Hub Bore size (if known): 73.10
Hub Centric Rings Required? Y/N: Y
Tire Size Front: 235/35/19
Tire Size Rear: 275/35/19
Tire Make/Model: Mayrun M800 front Mayrun M500 rear
Tire Air Pressure Preference: 37psi
Suspension: Megan EZ
Fenders Rolled/Altered: Rears have been shaved
Does the setup rub?: No
Pics Below:
![](http://i48.tinypic.com/35i4xm0.jpg)
![](http://i47.tinypic.com/124itf9.jpg)
![](http://i49.tinypic.com/2n8c0h4.jpg)
![](http://i49.tinypic.com/2j3qkas.jpg)
![](http://i48.tinypic.com/2jc8nyq.jpg)
![](http://i48.tinypic.com/1zez9fq.jpg)
Wheel Brand: TSW
Wheel Model: Strip
Offset Front: +40
Pics Below:
![](http://i50.tinypic.com/27zff3d.jpg)
#2289
Wheel Brand: TSW
Wheel Model: Strip
Offset Front: +40
Pics Below:
Wheel Brand: TSW
Wheel Model: Strip
Offset Front: +40
Pics Below:
how low did you go? (fender to ground)
#2290
Wheel Brand: TSW
Wheel Model: Strip
Offset Front: +40
Pics Below:
Wheel Brand: TSW
Wheel Model: Strip
Offset Front: +40
Pics Below:
Do you think you can run the rear spec without shaving/modification?
#2291
i am not out racing or railing corners just rolling to get from A to B so they work for me too
I didnt slam it
I just basically got rid of all the fender to tire gap
front tuck just abit as with the rear
there is room to go alot lower thougheasily fender to rim if wanted to
if i dropped it even more and stretched a tire abit yea
but i like to run proportionate width tires to the wheel width
if you dont run a 5mm spacer yes it could work easy
at current height i could possibly go maybe 5mm more
i have a custom 7.5mm spacer so I am gonna run that next
but will add extended studs to be safe
#2293
IS Year/Model: 2006 IS350
Wheel Brand: Motegi
Wheel Model: MR125
Wheel Size Front: 18x8
Wheel Size Rear: 18x9
Wheel Finish: Matte Black
Lip size front (if applicable): N/A
Lip size rear (if applicable): N/A
Lip finish (if applicable): N/A
Offset Front: +35
Offset Rear: +35
Hub Centric Rings Required? Y/N: N
Tire Size Front: 225/40/18
Tire Size Rear: 255/40/18
Tire Make/Model: Michelin Pilot Super Sport A/S
Suspension: F Sport Springs
Fenders Rolled/Altered: No
![Name: DSC02400.jpg
Size: 345.5 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/429072d1501343030-aftermarket-wheel-owners-post-your-setup-dsc02400.jpg)
![Name: DSC02401.jpg
Size: 281.3 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/429073d1501343030-aftermarket-wheel-owners-post-your-setup-dsc02401.jpg)
Wheel Brand: Motegi
Wheel Model: MR125
Offset Front: +35
Offset Rear: +35
![Name: IMAG3644.jpg
Size: 172.9 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/429074d1501343030-aftermarket-wheel-owners-post-your-setup-imag3644.jpg)
