Aftermarket Wheel Owners Post Your Setup
Old 09-29-13, 07:14 PM
  #2311
pearllex09
pearllex09's Avatar
I like those bbs reps. What brand are they?
Old 09-29-13, 07:17 PM
  #2312
bob4256
bob4256's Avatar
Originally Posted by lateapex
BBS LM reps, fronts 19x8.5 +35 225/35R19, rear 19x9.5 +35 275/30R19, on oem springs.
Flame on!
Nothing wrong with having replica wheels, just dont pass them off as authentic with BBS center caps
Old 09-30-13, 07:12 AM
  #2313
lateapex
lateapex's Avatar
YSM 944, in hyper silver, I got them from an importer that has a whole container full. Came with caps and he even gave me hub rings!
Old 09-30-13, 07:31 AM
  #2314
lateapex
lateapex's Avatar
Yeah I know it's ****ty to run the BBS caps but I think it's better than no caps at all. I just had them mounted on Saturday and have gotten many compliments about them, I let everybody know they are reps, even the guy at discount tire offered to buy them on the spot.
I am experiencing light rubbing when turning and hitting a bump and also in dips. I'm running 275/30 19 on the rear, what tire size do you guys recommend? I'm currently OEM but will swap in a set of H&R springs to reduce the wheel gap.
Old 09-30-13, 08:04 AM
  #2315
sm1ke
sm1ke's Avatar
You can go to 265/30, or just roll your fenders. I think rolling would end up costing less.
Old 10-01-13, 07:33 PM
  #2316
SCWB
SCWB's Avatar
Are you rubbing on the rear? I am running 19x9.5+35 with 255/35/19 in the rear. Zero rubbing no matter what. However I am thinking of running 5mm spacer to make rears even more flush. Will try them out soon.
Old 10-02-13, 05:49 AM
  #2317
lateapex
lateapex's Avatar
Very slight rub on highspeed sharp turns or on big dips in the rear. The rub is so slight that there aren't even any marks on my tires yet.
Old 10-02-13, 07:48 AM
  #2318
alee350
alee350's Avatar
19x9.5 w/245/35/19 front 19.10.5 w/265/35/19 rear #racekor
Attached Thumbnails Aftermarket Wheel Owners Post Your Setup-2013-09-22-19.40.52.jpg
Old 10-02-13, 09:25 PM
  #2319
PumaFiveOh
PumaFiveOh's Avatar
Need help from the Wheel/Tire gurus.....
I'm currently running (F19x9) 235/35/19's and (R19x10) 265/30/19's, but I want and need a wider/taller setup. The tires right now are too thin and a bit too stretched, so I'm thinking of going 245/35/19's and 285/30/19's. Can you guys tell from the pictures if I'm going to run into any rubbing issues?
The back is pretty high, so I think it'll be okay....but the front is too low and will be raised back up about a half inch or so, and I'm hoping that'll be enough to clear the 245's? What do you guys think?
Any advice is appreciated, thanks!
Old 10-03-13, 06:34 AM
  #2320
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
Doesn't look like much of a stretch to me... on another note - what wheels are those? They look like Avant Garde M359, but I've never seen those in a 5x114.3?
Old 10-03-13, 09:05 PM
  #2321
SCWB
SCWB's Avatar
Using 245/35 front and 285/30 rear. If you raise your car by 0.5 inch, you might be able to get away with rubbing. Based on my experience, you will rub on the front with 245/35 and raised ride height. But the rubbing should be minor.
Are u rubbing with current tire setup? It will be better if you can tell the offset of the wheels.
Old 10-03-13, 09:10 PM
  #2322
SCWB
SCWB's Avatar
That's a good news for me. Thanks for your reply
If possible, please share more pics of your rear from side angles, Thanks.
Old 10-04-13, 11:52 PM
  #2323
wilsonwho
wilsonwho's Avatar
How would my car handle if I ran...
Front: 19x9.5 +12
Rear: 19x10.5 +22
Would it be better to run 9.5s all the way around or 9.5/10.5 +22 all the way? I'm lowered on coilovers and this is my first time EVER looking into wheels so I'm just trying to figure out how aggressive of an offset this will be. Any input from Tire/Wheel gurus would be much appreciated!
Thanks in advance
Old 10-07-13, 07:49 AM
  #2324
NickTomsyc
NickTomsyc's Avatar
Vertini Fairlady
Front 19x8.5 225/35/19 offset 35
Rear 19x9.5 265/30/19 offset 45
H&R Springs
Old 10-21-13, 04:08 PM
  #2325
lateapex
lateapex's Avatar
Put my LM Reps thru hell this weekend, no bends or cracks yet.
Attached Thumbnails Aftermarket Wheel Owners Post Your Setup-fake-wheels.jpg
Quick Reply: Aftermarket Wheel Owners Post Your Setup
