Wheel Make & Model: Lexus F-Sport 19" Rims
Wheel Size (diameter and width): 19x8.5
Wheel Offset: Stock offset?
Compatible with tire pressure sensors? Yes
Tire Make and Model: Michelin Pilot Super Sport Radials
Tire Size: 225/35ZR19
Winter:
Wheel Make & Model: 18x6.5 ET40 CB71.5 Steel Black
Wheel Size: 18x6.5??
Tire Make and Model: Michelin X-Ice Xi3 95H XL
Tire Size: 225/45/18
Problem: The Winter set rubs a little on sharp turns and only when coming out of a turn. Not at all when going into one. Anyone know what could cause this?
So I spent an hour going through this thread to find the perfect rim/tire combo for my AWD 250.. and I still dont know. I plan on putting 19" Vossen CV3s , I want to keep stock height but have maximum concavity (if thats a word). Any suggestions?
Just my $0.02, I have 18x8.5 rims all around on my awd 250.. running 225/40/18... It looks odd without a drop. With 19's its going to look even more awkward. Doesn't matter if you get "bigger wheels to fill the wheel well" -it only makes it worse as you would sit higher...
If you're on a budget, go with 18s (can be cheaper as opposed to their 19 equivalent), and save for springs or coilovers (coilovers recommended--- I'll have mine on in a few months)..
I read through a lot of this thread but did not ever find anybody with the setup that i am considering so I am now wondering if it is able to fit. I was looking at getting XXR 530s in 18x9.75 +20mm offset for fronts and rears. Would these work? The closest I could find was 19x9.
Need some help guys. Will a 19x8.5 +35 and a 19x9.5 +32 work? Will I have rubbing issues? Car is currently stock height, but will be going on coil overs soon. How low can I go?
They're adjustable so you can go as low as you want or as safe with out bottoming out to the point where you'll rub on the fender.
Really? Will I need wheel spacers or anything? Offset is +24. I won't run into wheel well running with that wide tires in the front? I didn't find anyone else running 265mm tires in the front
2007 Lexus is250 rwd on Megan EZ Coilovers. Looking for best tire fitment that requires a slight stretch and as narrow as possible that won't shred my fenders lol
19x9.5+22/19x10.5+30<br/>Shop offered me 4 sumitomo tires balanced, aligned and mounted for $640 and ironmans for $520. Looking for budget friendly tires
