Aftermarket Wheel Owners Post Your Setup
#301
#303
Lexus IS model: is250 6mt
Wheel Make & Model: work emotion kai's
Wheel Size (diameter and width):18x8.5 18x9.5
Wheel Offset Front: +37 need a 5m spacer to make flush tho
Wheel Offset Rear: +30
Compatible with tire pressure sensors? yes
Tire Make and Model:the factory tires
Tire Size Front:225/40/18
Tire Size Rear:255/40/18
ill get more pics if anyone needs them
![Name: Picture103.jpg
Size: 59.0 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/441281d1501411128-aftermarket-wheel-owners-post-your-setup-picture103.jpg)
![Name: Picture099.jpg
Size: 106.7 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/441282d1501411128-aftermarket-wheel-owners-post-your-setup-picture099.jpg)
#308
Lexus IS model: IS250 Luxury Package
Wheel Make & Model: ALGERNON Japanese 2 pcs forged
Wheel Size (diameter and width): 19x8.5 &19x9.5
Wheel Offset Front: +28
Wheel Offset Rear: +28
Tire Make and Model: Toyo T1R
Tire Size Front: 235-35-19
Tire Size Rear: 275-35-19
Lowered with Tein CS
Wheels are not compatible with the TPMS
![](http://i51.photobucket.com/albums/f360/ThaiGoldenTree612/IS250/IS250002.jpg)
![](http://i51.photobucket.com/albums/f360/ThaiGoldenTree612/IS250/IS250005.jpg)
![](http://i51.photobucket.com/albums/f360/ThaiGoldenTree612/IS250/IS250001.jpg)
#312
Sorry for the misunderstanding. I forgot to mention that I added the spacers which now decreases the offset. They use to be 33 in the front and 38 in the back. I put the 5mm spacers in the front and 10mm in the front, therefore both front and back now has an offset of 28mm. If I knew the IS can fit 19x9.5 with a 23 offset in the back, I would've picked that specific size to maximize the lip. I'll share you guys my plan. When I do need new rear tires, I will get the 15mm spacers for the back and stretch 265 series tires. It might sound crazy but it would be just the look I want for my IS and would be flush as hell.
I hope that this info would be useful for those people looking for an aggressive look. I went through the frustration of not knowing so here is my contribution to CL members. I also had to shave a portion of the rear fender to make this possible. I encountered some rubbing going through hard turns but I already made sure it wasn't rubbing dangerously.
#315
![](http://i3.photobucket.com/albums/y95/epidemiksx/Picture103.jpg)
![](http://i3.photobucket.com/albums/y95/epidemiksx/Picture099.jpg)
