Aftermarket Wheel Owners Post Your Setup
#1060
I dont' see why RocketGuy3 needs spacers? I think his setup looks fine. It looks flush to me.
H&R are def. good and the 5mm ones will cost you around 100.00. Gernby is right when suggesting those, but I am still trying to see a better pic of the front.
could it be that those 18's and that is what is throwing everyone off?
#1061
The front wheels are definitely a little bit tucked. They probably still would be with 5 mm spacers, too, but it'd likely be hardly noticeable.
It's most obvious in these pictures:
If you still can't see it... then, well that's good I guess, heh.
EDIT: And are you talking $100 just for a pair? Or for a full set of four? I'll have to look into this a little more closely when I get home.
#1063
Lexus IS model: 06 IS350
Wheel Make & Model: Blitz Technospeed Z1
Wheel Size (diameter and width): 19x8 19x10
Wheel Offset Front: 45
Wheel Offset Rear: 45
Compatible with tire pressure sensors? no
Tire Make and Model:Pirelli P Zero Nero Summer
Tire Size Front:235/35/19
Tire Size Rear:275/3019
Suspension mods:Eibach prokit 1.0 & 0.8
15mm spacer in the front with long studs to clear the brake caliber (still little rub in the front)
#1065
Enkei Racing Series GTC01
Update to my previous post since i got rid of the Hyperblack color and painted the wheels in Ultra Silver.
2006 IS360 Tungsteen Pearl w/black interior
Enkei Racing Series GTC01 Ultra Silver
Front: 19 x 8.5 Rear: 19 x 9.5 (Weights 23 pounds)
Wheel Offset Front: +22
Wheel Offset Rear: +42
Compatible with TPMS
details on wheel: http://www.enkei.co.jp/en/p_detail_gtc01_pri.html
Tire Make and Model: Toyo TIR (Threadwear 280)
Tire Size Front: 235/30/19
Tire Size Rear: 275/30/19
Suspension mods: Tanabe Sustec NF210
Amount of drop: .8" in the front and 1" in the rear
No Rubbing.
No Rubbing.
