Vibration in steering wheel!
Well where to start.
I have had my IS250 RWD since November. I bought the only car the dealer had in stock which was demo with 1700 miles. Once I became comfortable with car i started to notice a slight, but very annoying vibration in the steering wheel between 70-75 mph. I took it to the dealer a total of 5 times.
The first time they rebalanced the tires.
The second they told me i had 2 bent rims (the front 2)-we all know how heavy and solid those factory rims are...I would have known if I hit something. The told me that it would be $200 dollars to straigten the rims (I paid half $100)
The third time they said the newly re-bent rim wasn't balanced correctly
The forth time balancing again
The fifth time the supposidly replaced the front wheel with a PDI car.
I have been driving the car this way for about 1-week and the problem is now more in the 75-80 mph range.
What should I do? Anyone have this problem or are your cars smooth in the wheel at all speeds. When does lemon law come into play or does it with this type of issue?
-- I relize this a supposedly a sports car and I can tell the differance between road feedback and a odd vibration. Thanks for repsonses in advance.
I've had mine well over 80 MPH also and the steering wheel is silky smooth and crusing 75-80 MPH in 70 MPH speed limit areas. So it's definitely not normal. At this point, I would be writing/calling Lexus Corporate to complain. Five times is way too much.
Only other thing that might be of consideration is the quality of the roads you drive on but it sounds like it's not.
Cheers,
Kermee
Cheers,
Kermee
Super Moderator
See if your dealer has a road force tire balancer. More specifically, see if they have a Hunter GSP 9700. From what I've heard, it's nothing short of amazing at finding and solving difficult tire and wheel vibration issues.
If they don't have one (my Lexus dealer does!), use this finder to locate a shop in your area that does. http://www.gsp9700.com/pub/search/findgsp9700.cfm
P.S.
My IS350 has no vibrations at all up to triple digit speeds.
P.S.
P.S.
P.S.
Cheers,
Kermee
EDIT: Looks like Lexus of Seattle, my dealer, owns one.
Go get your wheels re balance.
If the steering wheel slightly vibrate around 60 mph or up, balance at least 2 front wheels. If your whole car or even your rear are feeling vibration, get all four wheels balance.
When the tire shops are balancing your wheels, please ask them to show you once the wheels are on the spinner. Make sure your wheels are not wobbeling. Maybe you bent one or two of them.
Sorry campers, but if a dealer can't manage to balance wheels, which is a monkey's task, then you've got bigger problems.
Threaten lemon law litigation. That should get them fired up.
They have balanced my original set of wheels 2 times. Then they re-bent my "bent rims" (yea right) and balanced them twice. As a last resort they replaced the wheels. Problem still exists. I guess I am going to send Lexus Corp a email.
Thanks for the comments.
Super Moderator
Originally Posted by shaolin
YOu don't have to use the newest or the best balancer to balance your wheels.
The place where I go for my tire/alignment work told me that the Chrysler dealer used to send over Caravans with vibration problems they couldn't solve, and his GSP-9700 would sort them out on the first try.
Given the amount of grief the OP has been through, I'd definitely give roadforce balance a try.
The chances of a Lexus dealer NOT having a roadforce balancer are slim to none. If you do a search for shops with them in your area, you'll see that just about everyone has one (or at least they do around me... and 90% of those places I'd never bring my car to).
