5K service done
Originally Posted by United #10
Just took my car to the dealer for 5k services yesterday. Overall experience is great. The advisor is very helpful. Also, I asked him to do the 3 things on my car.
- Turn off DRL.
- Install front liences plate
- Realign the door handle cover because it is not flush with the body.
Everything is done except the door handle cover. The tech found the doorlock cylinder cover broken. . They need to order the new one. Again, Lexus Service is GREAT!!
- Turn off DRL.
Damaged wheels after 5K service
Originally Posted by 4TehNguyen
haha remember that one thread, that apparently didnt stop one lexus tech
well, it happened to me too..but in my case I wasn't so lucky.
I drove off the lot, I knew something was wrong then I decided to stop at a gas station to double check (less than 3 blocks) and *BAM*, my car didn't make the curb (it should have if the wheels were put on correctly). I damaged my front and rear passenger wheels (I thought about taking pictures, but I would have cried looking at them)
So, I took it back.
Basically they said, OOPS, that never happened before. So they have my car now, I got a rental and was told it would be repaired or I'll get new wheels tomorrow. We'll see what happens.
Lesson learned: Look at your wheel before leaving the lot...
I was too much in a rush to get back to work to double check...
Originally Posted by Kamikaze2b
It depends on which wheel/tire package you have. The 18's with high performance tires can't be rotated.
Originally Posted by DaveGS4
daytime running lights
I'm waiting at Lexus Of Seattle (Kuni) in the lounge for them to do my 5K and to turn the automatic DRL's off. From the sounds of it, I'm one of the first IS'es to come back to their dealership for the 5K. Second, it sounds like I'm also the first one to ask for the automatic DRL's to be turned off too.
Guess we'll find out in the next two hours!
Cheers,
Kermee
Cheers,
Kermee
Originally Posted by ES3
Anyone here actually like the DRL? I'm actually enjoying it, sort of sets the car off a bit in the daylight. I suppose the whole safety concept isn't a bad thing to follow either...
Right, you can go side to side, but I'm not sure what good that would do?
Originally Posted by diablo1
Actually you can't go side-to-side. The stock 18" tires are directional, meaning they are only meant to work one way. So it wouldn't work if you swapped side-to-side.
Originally Posted by Kermee
Just got shot down on turning off automatic DRL's at Kuni (Lexus Of Seattle). Just an FYI. Haven't checked Lexus Of Bellevue (O'Brien Group) or Lexus Of Tacoma, yet.
Cheers,
Kermee
Cheers,
Kermee
Sounds like your not giving up and that's a good thing!
TripleL
