1SICKSCANS! IS 250 MANUAL short take in Car and Driver
Guest
Posts: n/a
Originally Posted by daveortega
I love the IS and all, but horsepower doesn't tell the story here. First of all, this is the detuned 330i engine--yes, that makes 255-hp. And while it's true that BMW's 325i 3.0L makes 215-hp, it more than makes up for it with it's powerband. Case in point: C&D tested the new 325i and acceleration, on average, was about a second quicker. On paper, there is only a 11-hp difference, but on the road, the BMW will walk the IS250.
While the IS350 vs 330i comparisons are fun, the reality is that most car buyers are buying IS250s and 325i's. The IS350 is a formidable competitor to the 330i because of it's ridiculously strong powerplant--this is simply not the case when comparing the lower-end models. With BMW on the verge of upping the ante with the new base 328i (which will widen BMW's performance and marketshare lead), Lexus IS250 will be even more relatively underpowered, facing off a freshened (and likely lower cost) G35 .
I mean, people complain but the IS 250 has .5 less diplsacement, a whooping 11 less hp than the IS 300 but it has MUCH and I mean MUCH better fuel economy and the car is as fast.
As for the G35, since they offer one engine, and its a 3.5, it's priced like an IS 250 but goes like an IS 350.
Originally Posted by 1SICKLEX
I believe the 325 doesn't have the double vanos, correct? Thus the lower hp. I am not knocking the BMW at all, I always say BMw ponies are either underrated or at least as healthy as you can get.
They better improve it a lot--the current G is too bland for my tastes,
BMW needs 3.0 liters to get 215hp. LExus needs 2.5 to get 204hp. BMW just dumped the 189hp 325. I wish the IS could lose more weight, is anything.
I've seen numerous posts on this board stating that BMW's engines don't make as much power per liter as the Lexus engines, or that BMW "needs" forced induction to match Lexus. Those statements are ignorant and flat out wrong - the current N52B30 in the 330i makes just as much power per liter as the 2GR-FSE. Let's not forget the S54, making well over 300 hp out of 3.2 liters. Obviously, if BMW developed a 3.5L engine (which I don't see happening soon, since the bore spacing in the N52 block limits a maximum displacement of 3.2L), it should be fully capable of ~85-88 hp per liter just as the 2GR-FSE and VQ35 are.
Most in this class buy 325s and IS 250, C240s etc, not HP freaks.
If you want more speed, that is why you CAN choose the 350 if you want to dump more $$$$.
Lexus has left enough room between the IS250 and IS350 that they could easily fit a 240-250 hp IS300 model in there somewhere and open up the pricing a little bit (push the IS250 downmarket and the IS350 upmarket slightly).
The 325 engine also has Valvetronic. The only physical differences between it and the 330 engine are the intake manifold and ECU.
Very nice. IS250 is quite a bit slower than the BMW 325, but I am very impressed that as Lexus had initially promised, the IS250 6 speed manual although with almost 200 lbs more weight and smaller displacement put downs the same hp and performance numbers as the 1st generation IS300 5 speed. Definitely the close ratio of the 6 speed manual helps it keep close to it's peak power. Great job Lexus. Modern technology owns.
