How do you remove the subwoofer grill from an IS350 w/ML?
Registered User
I normally listen to Depeche Mode, Cure, and 80's. One day I decided to throw in the CD Too Short "blow the whistle", crank up the volume to 40 with bass setting +2, and within a few minutes I started to hear the sub rattle.
Don't get me wrong, I love my IS350. The best car I've own to this date.
Registered User
Originally Posted by IS_250
i can honestly tell you guys that there isnt much room so whatever sub you decide to replace it with needs to be pretty shallow. i have the factory pioneer system and not the ML but the sub should be the same size and location.
If its really 7.5" and no depth for a real sub. then we might have to find the wires going to the sube and neatly tape into them, then dissconnect them from the sub and run a small amp mounted to a small box in the trunk. For a personal 10" sub in the trunk. If you dont want it any more easy to go back to stock. Just removed the box and amp and plug back in the stock sub. I thought someone did this already. Can they give us some pics and wire colors for the rear sub?
honestly when you look at the rear deck you are looking at the sub. there is no access to remove it from the trunk. if you remove the upper trunk liner it is solid metal. i didnt actually take the rear deck out. i disconnected the stock sub and tapped the signal to run a seperate sub and amp. if i had known the factory amp was on the trunk floor i would have never had to take the rear seats out i did a write up on it while back.
JL makes a 6in sub that rocks house build a baffel board to take up the space and seal up the stock encloser and dynamat it put a hilo converter on the stock sub wires and throw in a jl 250/1 and you should be happy
Originally Posted by Phillip31
What would you suggest on how to install an after market sub and amp? Coz i already have subs and an amp in my truck and i want to install them in my IS 250 now. So ur sayin to tap into the factory amp wires to get the signal instead of the wire from the sub? You had to buy an RF converter or something right? Also, where did u run the wires thru to get to the battery? Thanks
https://www.clublexus.com/forums/sho...d.php?t=187127
this should help answer some of your questions. pm me or post back if you need any other details.
search is your friend...
