Break in period
#31
Originally Posted by t0e
Do not drive at excessively high speeds? Humm Doing 80 in the IS is like going 50 in a normal car. So just what should we consider "excessive?"
You can be riding only 30 MPH, but if you are reving 8000 RPM, that's excessive.
#32
Originally Posted by PhilipMSPT
I consider "excessive" to be under high RPM, not MPH.
#33
Originally Posted by rominl
i agree, speed shouldn't have that much issue, the rpm is what counts imho
#34
Originally Posted by dfw350
I am at 650 miles right now and the car feels a bit more responsive and easier to accelerate.
I have not taken my car over 3000 RPM's and over 75mph at all.
I think I am going to keep it up until I hit 1000 miles.
Obviously if youre leasing - there is no breakin
#35
Originally Posted by liverichly
I don't have an IS yet.. but you haven't taken yours over 3k RPMs yet? What is the max RPM when it changes gears automatically (assuming you have an auto not stick)? My stick Civic Si "feels" ready to shift gears at around 4,000-4,200 RPMs but I notice when I drive my girlfriends auto-G35 it automatically switches gears around 3,000 RPMs unless I use the triptronic, then I like to switch around 4,000. When taking the IS350 for a test drive I used the paddle shifters a lot, switching gears around 4,000 RPMs... would that be a higher than normal shifting RPM for the IS?
#36
Originally Posted by Bichon
It depends on how hard you are pressing the gas, whether the selector is in "power ECT" mode, and to some extent how hard you've been driving recently. Floor the gas pedal, and the car will shift at a very high RPM, at or near red-line. Drive it like grandma and it will shift at well under 3,000 rpm.
#37
just drive the car normal. if you need to push to merge onto the freeway, then do it. your car will not die or fall apart, or become weak if you redline your new car. sorry to break some of your hearts, but your car has been redlined many times before you took delivery of your vehicle.
#39
I have a little over 600 miles on my new IS and I didn't bother with any 'break-in' period. Maybe I should have, but I have been told that breaking in a car is not necessary for most Japanese foreign cars (ie: Lexus, Toyota, Honda, Acura)
#40
I didn't worry about break in either. Just drove it like any other car, I stomped it occasionally to pass someone, but never redlined it, which I try not to do anyway. For this theoretical damage you might do which will shorten the life expectancy of your car, what are talking about - 10 or 15 years down the road?
#41
I don't understand how some of you are making these claims that break-in is not necessary.
Unless you're a Toyota engineer, are privy to accurate inside information, or are reading documentation from Toyota that claim this, I'm more inclined to believe the printed manual.
why not follow the manual for a lousy 651 miles?
#42
#44
Originally Posted by Gekko
IMO
1. drive easy for first 1,000+ miles
2. get your first oil change early (2,000 miles)
check out -
Drive It Forever: Secrets to Long Automobile Life
by Robert Sikorsky
IMO
check out -
by Robert Sikorsky
