CAI question............
Old 03-21-06, 08:26 PM
stangd1909
stangd1909's Avatar
Default CAI question............
Does anybody have or know anything about this CAI??
http://cgi.ebay.com/ebaymotors/FUJIT...47296963QQrdZ1
Old 03-21-06, 08:39 PM
Foxberry
Foxberry's Avatar
It's not a CAI, it's a short ram intake. Not sure if anyone on here has the Fujita installed yet.
Old 03-21-06, 10:19 PM
yellowssm
yellowssm's Avatar
I think someone already has it on his IS. I think I have seen dynos somwhere on this forum, but i think there was only a 3 hp and 3 tq gain. I think ill pass at those numbers and wait for a REAL CAI.
Old 03-22-06, 02:24 AM
stangd1909
stangd1909's Avatar
^^^^^ Ya I agree with you.....3hp and 3 TQ isn't worth the money!
Old 03-22-06, 05:25 AM
caymandive
11 Second Club
caymandive's Avatar
Yes,
I was one of the people that got an intake of this type and did some dyno's. I can tell you from experience the intakes DO NOT MAKE POWER! They actually cause you to lose power on the dyno, not sure about on the road driving. I consistently made -10hp/tq on the dyno with the new intake until I decided to add a second fan to direct more airflow towards the new intake. Guess what!? Car made about 2-3 more hp then stock until 6000rpm where it was making less then stock.
Not to mention the intakes are noisy, which is a good or bad thing depending on your tastes.
My original thread is HERE
Old 03-22-06, 06:03 AM
4TehNguyen
4TehNguyen's Avatar
IS intake is actually very good already, some engines like the honda K series gain a good amount of power from intakes, ask any K series enthusiast
Old 03-22-06, 07:37 AM
Tony1
Tony1's Avatar
So much for LMS Products
Old 03-22-06, 09:04 AM
uschardcor
uschardcor's Avatar
which is why intakes like joe-z's do the best job when used with a drop in filter
Old 03-22-06, 03:47 PM
CarbonIS300
CarbonIS300's Avatar
Originally Posted by caymandive
Yes,
Was this dyno taken right after install or did you drive around about 500 miles first?
Old 03-22-06, 06:41 PM
caymandive
11 Second Club
caymandive's Avatar
quote from my original thread "I forgot to mention that there was no disconnecting of the battery before any of the dyno's or after. Original baseline dyno was done a few weeks ago, installed the LMS intake over a week ago and have about 300miles on the car with the LMS intake so my ECU has learned the new intake modification and has adjusted appropriately. These are real results with no tricks played like doing a dyno right after installing the intake or resetting the ECU, which almost always yields gains due to the car running leaner until the ECU learns."
Old 03-23-06, 08:19 PM
CarbonIS300
That’s why I asked, the correct way to do it is dyno the car then replace the intake then reset the ecu then drive car 500 miles then come back and dyno. The other issue is because is it’s a different day with different tempratures and what not means that there is no possible way to correctly dyno for results. In addition there has been one person from .net that found he could change the dyno results by moving the fan direction on the front of the car and it changed the results as much as 10 WHP...
Old 03-23-06, 10:54 PM
Ramon
Ramon's Avatar
A buddy of mine has the fujita on his IS350 and it is the EXACT same thing as the LMS intake only under the fujita label.
xianan87
Performance
12-29-10 09:00 AM
Letsrunem
Performance
35
02-12-08 04:50 PM
lexus250
10-22-07 11:26 AM
07IS350
Performance
11-01-06 03:09 AM
caymandive
Performance
03-31-06 06:49 PM
Quick Reply: CAI question............
