Sport Pedal Install
#62
mooncake master
Originally Posted by Dj Rando
how did you do the acc pedal Pocky?
#64
mooncake master
I'm confused, there are only 2 nuts that you removed to get the pedal off?
Of course I used the easier, yet a little harder to reach method and just took the whole unit out like AndyL did.
#67
iorchii,
I bought it from a Ebay listing by Sewell Lexus. It's a 3-piece set deal (accelerator, brake pedals and the footrest/dead pedal) for US$99 + shipping.
Dealt with Darrel Diller and he was quick to ship.
ULTiMaX99,
You may try to see if Sewell Lexus has it. Remember to use the CL promotional code(CL911).
Dj Rando,
Yes, only two nuts. I was surprised to find it out when I worked on it. The nuts are located diagonally. The other two nuts are for holding the L shape plate to the carpet and hence they shouldn't be removed.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Pocky,
Can't disagree with you about putting back the pin back for the accelerator. I was pondering for a long time and was afraid to bent the pin. I am glad that the pin is actually hollow which actually forces itself in (provided that the pin is positioned properly)
ULTiMaX99,
Dj Rando,
Pocky,
#68
andyl,
did you have to take apart the dash area in order to get to the two screws?
Originally Posted by AndyL
iorchii,
ULTiMaX99,
Dj Rando,
Pocky,
ULTiMaX99,
Dj Rando,
Pocky,
#69
Hi islandsnow,
Yes, I actually took apart the lower piece of dash before taking those 2 screws out as I couldn't see them clearly. The lower piece of dash is the one right below the knee air bag. It can't be taken apart completely -------- it can only be taken apart and hang there as there is something holding it. See I rotated it 90 degree in the picture.
Hope it helps.
Hope it helps.
#70
Hi islandsnow,
Hope it helps.
Hope it helps.
If I remember correctly I ended up removing that lower piece completely by disconnecting the sensor and led connectors. I used a large adjustable pliars to slowly squeeze back in the roll pin so I did not have to hammer it.
#71
Originally Posted by clubfoot
Hey AndyL,
Yes, this seems to be the best way since you are less likely to damage the surrounding of the hole.
#72
owww, my fingers. just installed the sport pedals into my car. almost freaked out becuase the accelorator pedal just fell apart after taking it out of the car, but luckily i figured it out. looks very nice now though. i used the 4 screw to take apart the housing method btw.
#74
The last I heard they weren't selling the gas pedal anymore because of the difficult install. If you can get it, it will cost you a boat load. I'd be curious to see if you can find them. I'd love to put them on my car.
#75
