VDIM bypass trick doesn't work on the 350 right? *flame disclaimer inside*
Old 03-30-06, 07:15 PM
G35TOIS350
G35TOIS350's Avatar
Default VDIM bypass trick doesn't work on the 350 right? *flame disclaimer inside*
been discussed many times I know, but the instructions in the Car and Driver ad about how to shut down the stability control doesn't work for the 350 does it? works with a hand brake not a parking break by the floor correct? I have a traction control button so this Nintendo shuffle with the break pedal and stuff doesn't work right? car doesn't have a hand brake.
*flame disclaimer*
yes I read the many posts on this. no I didn't see anything that specifically said it would or wouldn't work on a 350. its late, long day at work, and I'm sipping on Jack and Coke so I may have missed what I'm looking for. flame lightly..
Old 03-30-06, 07:31 PM
Payam
Payam's Avatar
It works on the 350. the traction off button on the dash deactivates after 25 or 30 mph so you still need to do the shuffle if you want it to stay off. But everywhere it says to pull the hand/e-brake, just push the foot e-brake.
ybing
ybing's Avatar
*flame disclaimer*
The hand brake means the foot parking brake (E-brake)in IS350
1: e-brake down (On) before start engine
2: start engine and apply brake twice and hold it down
3: apply twice e-brake and keep it down (keep the "brake" light on)
4: brake twice more then you will see the traction light on
Some people said this wont turn the VDIM completely off (still have some VDIM...I donno...) but there will be a huge different between turn off and turn on
Old 03-30-06, 07:53 PM
G35TOIS350
G35TOIS350's Avatar
ok *takes sip of drink*... so the brake is on when you start the car. does the parking brake stay on as your pushing the brake pedal down or after the car is started do you take the parking brake off then push the brake pedal. i tried it a couple times and it didnt work. *takes another drink*
Old 03-30-06, 07:58 PM
G35TOIS350
G35TOIS350's Avatar
ok just went and tried it.. and it worked!! sweet. thanks for the help and lack of flame. off for another drink
Old 03-30-06, 08:53 PM
Phillip31
Phillip31's Avatar
I just hope u dont test it out right now........drinking + driving IS 350 + Trac/VSC totally off = death
Old 03-30-06, 09:00 PM
Kipperm13
Kipperm13's Avatar
I have noticed that if you drive around for a bit then try it ...it doesn't work, so you need to turn the car off. But I have drove up the road a bit and then put the car in park and try it as well and it has worked with out turning the car off... it must have a sensor or something ..
Old 03-31-06, 04:53 AM
G35TOIS350
G35TOIS350's Avatar
uhh no. that would be dumb.
Matt3125
04-26-18 11:20 PM
ronsinsc
01-19-16 12:47 PM
now
ES - 5th Gen (2007-2012)
06-25-11 02:34 AM
jjwalker
06-20-06 10:25 PM
Quick Reply: VDIM bypass trick doesn't work on the 350 right? *flame disclaimer inside*
