HowTo: Hardwired Valentine 1 or other radar detectors (merged threads-read full post)
#211
ok i have a V1 and a 09 is350.. I read most of the pages here but still not sure on the correct connection..
is it..
red to orange and
green to blue..
or
blue to red and
green to orange??
is it..
red to orange and
green to blue..
or
blue to red and
green to orange??
#215
Sorry, i am not try to wire power cord to power Valentine 1. However, i want to know how much power it need to power this Valentine 1? I am doing a DIY get a 5v power wire for a Car DVR. The DVR will locate near the rear view mirror. My goal is use 5volts to power up the DVR. Or Using the DVR's OEM has power wires that require 12v power to power up. Anyone have suggest where i can start?
#216
how to wire v1 valetine radar to view mirrow?
i did exactly how to wire follow this post and it doesnt work.there is no power on.does anyone know about this and could help me out.Thanks really much
https://www.clublexus.com/forums/1838210-post32.html
#218
Definitely use a fuse. I did not and 4 yes later the cord shorted out. It turns out that the AC and power steering are on the same fuse as the mirror. So when I blew the fuse, I had no power steering and it took the dealer 2days to trace it back to my power cord.
#220
Forum Administrator
Did you check the FAQ sticky at the top of this forum? Pretty sure there is a big thread linked there for this
https://www.clublexus.com/forums/is-...tart-here.html
Edit - merged, just scroll up
#221
Just as an FYI, the 2011 Lexus IS350 AWD rain sensing wiper box has a white, gray, and black wire. The black wire is power, and the white wire is ground. I used the stealth cord and plugged the black wire into the white, and the red wire into the black.
#222
V1 install on a 2011 isf
Thanks to rys for letting me know this valuable info on using the power from the sunroof, install time 15-20 mins mainly to make sure the unit doesnt scratch or break stuff while doing install, rys u are right sunroof is the best place to wire. Here are some pics i also took of install. Didnt use the fuse either its much easier to change sunroof fuse.
#224
Just did this yesterday and for what it's worth on my 2006 IS350 using the actual V1 cable I had to go red to orange and green to blue for it to work. Once I did though it worked great.
Also...to double check if I go with the Country Joy mount I would need the 3/4" for the old style 2006 mirror correct?
#225
Looking to install my radar detector (escort x50). Kind of old, but do you guys still think it's a good one?
And what do you guys hard wire it to? I seen some old response about wiring it the moon roof? But is that safe, don't want any wires or harness to burn out.
Some of my friends said to wire to the radio fuse. And to use this:
http://www.radarbusters.com/radar-de....cfm?RNtt=fuse
And to use the direct wire cord for the Escort:
What do you guys think?? Thanks for the help.
