HowTo: Hardwired Valentine 1 or other radar detectors (merged threads-read full post)
Old 07-18-14, 12:37 PM
  #256
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default .....................
Originally Posted by kyoso23
Either way, if you get hit with a laser you're done anyway.
We are talking about helping early detection........once tagged who cares yes you done.
Old 09-11-14, 11:02 AM
  #257
JasonZ-YA
JasonZ-YA's Avatar
Originally Posted by WALDIS350
i cut off the black and yellow wires b/c you dont need them. then i stripped the ends and started twisting. i used a soldering to tint the ends b/c i felt that they were pretty thin and cripped on the pins:
i used heat-shrink tube to seal the ends so that it will stay in place and flatted the tips b/c they did not fit well
i took off the mirror which was showed previously and inserted the pins to the right wires. i have a passport escort so it was red to blue and green to orange (thanks comb)
You were able to get yours into the mirror side of the harness at the blue/orange ,but my pins were perfect round pins and wouldnt shove in and stay......but the car side of the harness was much bigger wire entrance and easily pinned for me.
Originally Posted by saxqtzk
I just did this yesterday. Car side of harness it's white/black and black. Mirror side is blue and orange
Black/white + positive
Black - negative/ground
ya, I used the car side simply because the car side of the harness had wider access to pin in the hardwired pin at the end of the pigtail wire i made.
I went to radio shack and purchased D9 sub pin connector p/n 276-1427, cost was $2.99:
From there i simply stripped the wire from a spare escort cable i had, the pig tail squiggle cord....uses a light tester and verified which wire was postive and which was negative and simply soldered the wires to the pins.
Car side connector is the side of the connector closes to the headliner - with the pins that most of the online kits come with and the pins i used from radio shack wont fit on the orange/blue side of the connector.
The car side has a much wider access of the wire and pushing the pins in was simple and held tight with no issue.
Car side:
From there, i just put the plastic harness cover back on and everything came out looking very clean looking.
My friend was happy to get this installed........his 2nd gen IS250 -2006.
-J
Old 10-10-14, 06:10 PM
  #258
aznkorboi
aznkorboi's Avatar
Default Update
FYI:
For 2009 Lexus IS250 models
I did exactly this..
Bought a BlendMount MT-2012 MirrorTap from amazon. Great customer service, fast shipping.
I have an autodimming rear view mirror with a concealed plug.
I was scared to do my installation because everyone used welding and removed the whole rearview mirror.
This was TOO easy.
All I did was remove the Car side black attachments that hold the cables together. That is done by simply 1. removing the outer covering by pulling out and to the side. Then 2. removing the inner black plastic covering by simply lifting up.
Exposed is the car side plugs with 3 wires, pink, black, and white with black stripes.
Now this install was so easy I kind of forgot what plug went where. I believe I put the red micro plug into the black compartment and the red plug into the black and white compartment. And by compartment I mean the small little plug that the cable runs into.
That's it. I simply plugged it in and fired up my Escort Redline with no issues.
Old 06-05-15, 05:30 PM
  #259
slickhoosi
slickhoosi's Avatar
Open the sunroof!
Old 06-28-16, 08:29 PM
  #260
Merzbow
Merzbow's Avatar
Originally Posted by "that boy"
(+) Red -> Orange on Harness
(-) Black -> Blue on Harness
2011+ Models:
(+) Red -> Black on Harness
(-) Black -> White/Black on Harness
Just hardwired a V1 on my 2016 GS-F. Tapped from the mirror harness, car side. Turns out the colors have changed yet again:
(+) Red -> Yellow on Harness
Old 11-05-17, 07:40 AM
  #261
calteg
calteg's Avatar
Can anyone help me with the wiring here?
V1 (yellow/green/black/red connector on the left) to a 2008 IS-F mirror. I've tried red->blue and green ->orange, as well as yellow-> blue green -> orange, neither worked.
Old 12-28-17, 09:22 PM
  #262
endlessct9
endlessct9's Avatar
Hi. Quick question (already did a site search but nothing specific seems to come up) - looking to buy a mount for my V1. 2017 GS 350 F Sport. Looking to buy a mount that attaches to the rear view mirror. Any help would be greatly appreciated. Thank you.
Old 12-29-17, 07:48 AM
  #263
XSV
XSV's Avatar
better luck posting in the GS forum, this is the IS
Old 11-29-18, 04:29 PM
  #264
goto35
goto35's Avatar
Did you figure out the colors? I have a 09 ISF and need to know which color is positive and which is ground?
finny76
GS F (2016-present)
05-03-18 12:00 PM
socaligs
02-01-17 10:31 PM
lexman52
11-04-15 10:34 AM
jjwalker
09-05-06 06:41 PM
jackleu
08-05-06 07:28 PM
Quick Reply: HowTo: Hardwired Valentine 1 or other radar detectors (merged threads-read full post)
