just installed HIDs
ok I just installed my HIDs. 6000k.
but theres a problem the driver side is lower than the passenger side, so when I adjust which side do I adjust? driver side adjust up or passenger side adjust down?
heres some pics stock:
![](http://i34.photobucket.com/albums/d146/tlsupramkiv/stocklights2.jpg)
HIDs
HIDs
![](http://i34.photobucket.com/albums/d146/tlsupramkiv/HIDs2.jpg)
The driver's side is supposed to be a little bit lower so it doesn't shine directly into the eyes of oncoming traffic. When you did the install, you didn't move the headlights did you?
Is it mandatory to adjust the headlights after installing these aftermarket HIDs? Some have said because of the glare that you should lower the beam, is this true?
Thanks
Thanks
Originally Posted by integlikew
Agreed. the drivers side is lower. So when on comming traffic just to the left of you is comming your right headlight is not so high and shining into their face. If you didnt already move them then DONT.
hmm then I guess i wont.....its raining so I cant anyway haha
Originally Posted by acl15
which bulbs did you get? and can you provide a link? thanks
Originally Posted by cespiritu
what is the temp of the factory oem hids?
Originally Posted by Sexi_Lexi
OEM is 4300k. Keep in mind that the higher you go in temp, the lower the light output. The only reason why higher temps "appear" bright is due to the glare/color that a higher temp puts out. If you want the best light output, stick with 4300k. Only thing w/the lower temp is that you won't get much color (if any).
Originally Posted by wolverine
so if i wanted to go to 4300k is it as simple as switching the bulb?
