First "FREE" Maintenance
Did anyone get the first free maintenance? I got mine last saturday and they charged me approx. $92 for a brake inspection (including cleaning and lubrication) and tire balancing. Do you think this is really necessary for the first 5K maintenance?
Basically, my first "free maintenance" only included oil and filter change.
Originally Posted by dkaplan435
...I paid $80 to have my 4 winter tires removed and summer tires put back on.
As for the first free maintenance, the inspection and service schedule is no secret. You should know this before you get the work done, long in advance. So you're probably on some other schedule since most of us are on the standard first free with free being $0.00 when you leave the facilities.
Mounting and dismounting might be as high as $20 per tire and that doesn't include the balancing, etc. If some TPMS work had to be done, that might have added to it also.
heck that is why i have summer set of rimsand tires and a winter set of rims and tires and a floor jack impac wrench and a torque wrench. but is a little complated with my air setup. you have to lift the car then put the jack under the car and rase the jack then lower the car then jack the car now you rotate tires then you lower the jack then rase car then lower jack and after all that you have to torque the lugs to 110 foot pounds. and that is just 1 side
who da what?
freeflight
06-24-14 04:34 PM
