What is the benefit of AWD besides in the snow?
for a quick note...AWD is a damn good system for cornering, but really only if the car has the ability to shift power to the wheels with the most traction. i mean it will work regardless but for the weight added that is the only way i really like it.
besides fishtailing and powersteering is SO much more fun! and by fun i mean potentially life ending at the same time
man you all are seriously bumming me out and giving me some hardcore buyers remorse for going with the AWD. The 350 is a totally different car with all that horsepower. And much nicer.
Well, at least I'll have my rims intact instead of those out there with a 350 that someday slides into the curb in light snow.
Originally Posted by Shinobi-X
I agree with just about everything said, but in the case of the GT2, its one of the fastest turbo cars porsche makes, and it outdoes the AWD cars in 0-60 and just about any other measure of acceleration. Countering the 50/50 balance idea (I don't know why this is marketed so heavily), the rear engine, RWD layout = If you can grab traction with two wheels, its 'better' than splitting the task to four.
Um... there are many differences between the GT2 and the Turbo, not just drivetrain.
For starters, the GT2 runs larger turbos than the Turbo (we are talking 996 here as the 997 info on the GT2 isnt finalized). You can opt for the X50 package with the Turbo however the boost is still higher in the GT2.
Also there are significant weight savings in the GT2 vs Turbo.
Larger Turbos, higher boost and weight savings (yes, partly due to changing from awd for rwd) are the reasons why the GT2 is faster than the Turbo.... not just the rwd.
Lastly, have you guys ever seen the S4s race at Le Mans? Those Audis, at the start of the race, literally jump 4-5 spots ahead instantly due to their superior traction and acceleration off the line.
How is it much nicer? If you mean much nicer by it having so many more horses then yeah. But isn't it basically the same car with bigger brakes and engine. Do you have a need for speed?
If you'd like to take the Carrera S and the Carrera 4S, you'll see they both make about equal 0-60 times, given similar hp. The rear weight distribution bias found in porsches, makes RWD a great setup for launches, especially as weight shifts rearward.
As for Audi, if your car jumps off the line, its because traction was made available by your vehicles contact patch, whether it be 2 or 4 wheels- if you're slipping, then AWD compensates, but what if you're not slipping? A hypothetical 100% traction in a RWD vehicle would accelerate just as fast as 100% traction in an AWD vehicle, with all other things being equal.
It also dependson how the AWD was set up, right?
ie., EVO and WRX systems were set up for performance, and I'd say the same for Audi's quattro and maybe BMW's xDrive systems. On the other end, MB's 4Matics are primarily for traction in terms of safety. Where does this put the IS AWD?
Exactly, the porsche GT2 is lighter than the AWD 911 mainly because it is RWD, saving the majority of its weight in the drivetrain (this is the point). They also ditched traction control (saving more weight), yet 0-60 times made by the GT2 are superior to the AWD cars, despite the 'disadvantage' some people would like to say RWD has compared to AWD (which in the ideal should be more consistent).
In the dry, Drivetype isnt too important for a 200HP car, but when you get into 300+HP.. it makes a difference on the street. You can accelerate through a turn, you can launch the car, you can hit full throttle uphill in the rain.
On a 200HP car, the advantages of AWD are limited to control during inclimate weather. And greater control during turns. (Although, you can turn harder in RWD)
And finally, if there is 0% Slipage, an RWD car will be faster than the AWD car, due to added DT loss. However, on most RWD cars, there is some traction loss, maybe with the 18s(255s)... traction loss should be minimal.
Originally Posted by al503
If you live in the snow belt, AWD is great for that reason alone. However, if you're in an area that gets snow very seldomly or for a week or two a year, you might consider a good set of snow tires.
In terms of getting off the line, I actually tried that with a 250 AWD and a 350 and the 250 AWD gets off the line quicker (only to be smoked by the 350 within an additional second or two).
There is a Road and Track comparo involving the AWD IS that was discussed here before. In that comparo, they also looked at a RWD Infiniti G35 and compared it to AWD Infiniti G35. Since they are identical models, all your considerations about weight distribution, the extra weight etc. would have been accounted for. The bottom line is the AWD outperformed the RWD version for handling and posted better slalom and skidpad times. That I think should be a pretty good example as to how AWD might affect the IS.
Originally Posted by tqlla3k
That is not a fair, realistic or good comparison at all.
The GT2 has a 100HP, and 400lbs weight advantage over an AWD carreraS.
And then you have to consider the power distribution, a car with closer to 50/50 power dist will have better launch charactoristics and more grip overall, a car with 30/70 will turn harder.
Sure it is. Porsche needs a flagship car that accels in as many areas as possible. They are partial to rear engine layouts and weight biases that see as much as 60% in the rear. So, they accomdate this with a drivetrain layout that best takes advantage of this setup, and that happens to be RWD. Its realistic because its real world.
I digress a bit, but the case of the GT2 speaks for itself.
1) The weight of the motor is over the rear wheels.
2) The contact patch is probably 50% greater than the contact patch of the IS250
3) The tires are probably a lot more expensive than the ones included on a 250 or 350.
4) The Weight diff between an AWD carrera and an RWD Carrera is only 150 or so lbs. So the 400lbs weight loss of the GT2 is from more than just being AWD.
Yeah, good tires can make up a lot for RWD Drivetrain... but in this case, its just not realistic. We are talking about a car with 225s or 255s in the rear
As far as accelerating through a turn, yes it can be done in RWD on the street, however,
1) Feathering the Gas is not the same as hitting full throttle
2) LSD and traction control limit your acceleration
3) You had better be good or you will end up in a ditch, IE you are much safer in an AWD car.
Originally Posted by Turkoman
I would so much like to believe that. However, I think a RWD car is not made to be driven in the snow and are best kept it in the garage when it snows, with or without snow tires. And those who say otherwise are inviting agony to themselves if they keep pushing that concept in the snow. .
And as I've soapboxed before, the big problem with slippery conditions is usually steering and stopping, where AWD gives no advantage. In my opinion, the often-hyped-up advantage of AWD in the snow is pretty marginal. If AWD was the only reason the car was able to get moving, then you're going to have a nasty surprise when you go to steer and stop!
2. On a tighter, more technical track/autocross setting, the AWD car can and often does have the advantage where the front tires can pull them through the corner, which is exactly why it helps in the tight slalom and skidpad. The Subie STI and Mit. EVO come quickly to mind.
However, on a longer, less technical track, the RWD cars usually have the advantage.
3. Weight: Weight is the enemy. The effort and expense that racing teams go through to reduce the weight of the car and it's components is probably in the top 2 considerations. The AWD hardware adds weight period. This tranlates into additional wear and tear on almost EVERY suspension, braking, and driveline component in the car. Accelerating and decelerating 1 lb is easier than accelerating and decelerating 1.1 lbs. I can't argue against the laws of physics. Can you?
4. Weight distribution: The AWD components increase the weight where you don't want it for handling purposes. How many cars do you see in any racing circuit that has more weight over the front tires than the rears? All other things being equal, a car with a 50/50 weight distribution will probably handle, brake, and accelerate better than a car with even 51/49 (F to R) distribution.
Finally, there's a reason why you see the AWD Audi's (in the german racing series) passing several cars at the start.
1. they have the power overcome the inherent additional inefficiencies inherent to AWD, at the same time,
2. you have to ask yourself why they're not in the front row to begin with.
Originally Posted by yon
Balderdash. The wife's RWD SportCross is just dandy in the snow, thank you very much. Between the Blizzaks for grip, Snow Mode to keep the torque down, and Traction Control to keep the tail under control, it works out just fine.
That is not a valid comparison for this thread.
http://www.formula1.com/insight/tech...fo/11/462.html
