Xenon Depot HID 4300k Install (56k beware!!)
Old 08-22-06, 04:16 AM
  #31
b3dlam
b3dlam's Avatar
and here...
Attached Thumbnails Xenon Depot HID 4300k Install (56k beware!!)-120-2085_img.jpg
Old 08-22-06, 04:22 AM
  #32
b3dlam
b3dlam's Avatar
last one...from inside the car...
i am v happy with the kit!! i guesstimate that it puts twice as much light onto the road. Its similar to the stock hids on a is200 that i drove for awhile.
thanks steve!
Attached Thumbnails Xenon Depot HID 4300k Install (56k beware!!)-120-2078_img-resize.jpg
Old 08-24-06, 02:05 PM
  #33
StockIS350
StockIS350's Avatar
Originally Posted by CoasterG
Oooh Xenondepot overnights?
Awesome, can get mine installed on Thursday then!
ain't going to happen, I ordered from the 14th and I'm still waiting for my kit
Old 08-24-06, 03:26 PM
  #34
NovaIS350
NovaIS350's Avatar
Umm correct me if I'm wrong, but aren't the stock HID's 4300k? If I'm not mistaken Lexus uses the HID-D4S as OEM lighting on 2006 models. There really isnt any difference from the lights you're showing me and the stock IS350 lights. I would have opted for the 6000k or 8000k phillips xenEco lighting system
Old 08-24-06, 03:49 PM
  #35
javyLSU
2IS OG
javyLSU's Avatar
OEM's are 4100k, but this would obviously be for those of us that didn't get HID from the factory...
Javier
Old 08-25-06, 07:32 AM
  #36
AmmarithGS430
AmmarithGS430's Avatar
Post
Would I need Xenon Depot HID kit if the car already have stock HID?
Why not just replace the stock 4100k with Philips 4300k bulbs?
If someone could answer my questions I would appreciate it.
Old 08-25-06, 07:47 AM
  #37
b3dlam
b3dlam's Avatar
nopes
because the retrofit bulbs will not fit the housing. Plus it would not be any brighter/better.
Old 08-25-06, 08:14 AM
  #38
menech
menech's Avatar
Not every IS comes with stock HIDs...so people are getting the xenon depot kits to retro-fit.
If you got a package that included HIDs you can just replace the bulbs with whatever color you want
Old 09-02-06, 03:08 PM
  #39
omgitsroy
omgitsroy's Avatar
what size bulb should i be purchasing?
Old 09-02-06, 03:09 PM
  #40
omgitsroy
omgitsroy's Avatar
how do these compare to Mtech?
Old 09-02-06, 03:18 PM
  #41
NovaIS350
NovaIS350's Avatar
actually..the HID's on the 06 IS350 is a new design utilizing less power to emit the same amount of light as the D2S and D2R HID's of yester year. The new HID's use a D4S bulb from phillips which contains less mercury (environment friendly) and emits 3200 lumens of lighting at only 4300k. You can not simply upgrade the bulbs on the OEM ballasts because the igniters do no put out enough power to ignite the bulbs. Doing so with the phillips xeneco's would burn out your harness, igniters and ballasts (very expesnive to repair). But you didn't hear that from me, I got all of that information from the mechanic at lindsay lexus in alexandria, va. The lights don't look as blue as other cars, because the lights on the IS are tad bit brighter. the higher the kelvin output the less lumens output there is.
Old 09-02-06, 03:31 PM
  #42
shizmd
shizmd's Avatar
Exclamation urgent advice seeked
Hello I'm in the midst of installing the xenon depot HID kit on the IS350. So the wire that has the fuse along with it needs to connect to a positive terminal? Does this connect to the actual positive terminal on the battery? If so, can the driver side wire reach that terminal? Also where did you connect the ground to? I noticed two areas of the car where it may be grounded. Thanks for your help.
Old 09-05-06, 06:41 AM
  #43
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hello,
As per your posts:
1) You would need to order an H11 conversion kit for the new IS.
2) Yes, you would need to run the positive lead on the harness to the positive terminal on the battery.
3) You can ground the harness to any bare metal bold on the car body.
Steve
Old 09-05-06, 07:04 AM
  #44
omgitsroy
omgitsroy's Avatar
Old 10-16-06, 06:35 PM
  #45
Otsuka
Otsuka's Avatar
Am I the only one who cant see the installation pix? ..... i can see other pictures fine except the original installtion pictures ..
Quick Reply: Xenon Depot HID 4300k Install (56k beware!!)
