Better mileage with lower oct fuel??
Ran a tank of mid grade vs prem and got a bit better mileage. Same toll road with the cruise set at 80. Prem tank got 21mpg and the mid-grade got 24. Am I nuts or can the lower oct give you better mileage?
Cycle Savant
There are a lot of factors that contribute to gas mileage. Temperature, traffic, tire pressure, road conditions, use of a/c, time to warm up a car, etc, as well as fuel grade.
I think fuel grade is not a "major" factor to gas mileage, but rather the conditions in which the car travels.
Well if you happen to slow down a bit to around 65, you might be able to get 31 or 32 MPG, if its flat land. I did going to the beach in NC. Only had to rumble a little bit around Raleigh( to keep from getting run over). the 350 does real well with fuel mileage, and power
be careful out there.
The same thing happened to me last year (GS 400). I can't explain it, but it was a noticeable difference. I keep track of gas mileage religiously, and I usually get 20.5 to 21.5 on every tank. On the tank where I used the lower octane gas, I got 23.
Lexus Connoisseur
Lower octane fuels work better in higher elevations.
Originally Posted by t0e
It is also noted in the manual, if the engine detects lower grade gas mileage, the fuel injection process runs differently.
RX3302004
09-11-13 09:59 PM
