Need your help with a beeping alarm noise and a moon roof problem!!!!!!!!
this is absurd. youre saying you would rather repeatedly ask the same thing instead of modifying your own questionable behavior? I have gotten out of my car a few times and left it running purposely and yes it beeps. so what? I know how to make it stop.
Originally Posted by kensteele
These are not problems with Lexus or problems with this particular car. This is your personal problem.
The car is new to you and you have to get used to doing the tasks that you want done. It's a repetitive task that humans have to adapt to. Sooner or later, you won't be so easily fooled by the simple chimes. Pretty soon, it will become routine for you to reach up and simply turn the **** right before you punch the OFF button. If you can't get this down in about a month or two, for you I would say give it an additional month or two more....then after that you may want to consider getting rid of the car since apparently it's not working out.
this is quite a diplomatic way of saying something else. nice.
Originally Posted by tqlla3k
Whats wrong with opening the door, then turning off the car?
I do not see what is questionable about that.
Sorry for another bump... (im searching so i'm being good! )
But i have the same questions about the door ding. It's extremly annoying. I would love to turn this beep off. Anyone ever figure this out?
Thanks!
Thanks!
I've also noticed that the buzzer sounds if I open my door with the engine running. Actually, I've noticed the same on any car built since about 1970 or so.
The fix is to either:
a) Close the offending door; or
b) Hit the button that makes the engine stop running before opening said door.
I don't blame Lexus for not taking up their engineers' time finding a legal workaround for this. I'm sure they read this forum from time to time, and many of them almost certainly have the Japanese equivolent of that "built a better idiot" line taped up in their offices.
dbs600
01-31-14 09:00 AM
tommy329
12-18-13 11:45 AM
