Transfer Phonebook
Originally Posted by FrankyJ
Anyone know how to transfer the whole phonebook to the cars system for a Moto V3?
Super Moderator
Be glad you don't have the Verizon RAZR, they disabled the object push profile so you can't even transfer one contact at a time.
(I just flashed my Verizon RAZR with Alltel firmware, so I'm at least able to transfer contacts one at a time now)
OK, if my Cingular Razr can only tranfer one entry at a time how do you do it? My salesman tried for quite awhile but was unsuccessful. He had it saying it was transferring but when we looked at the phonebook it had multiple entries of the same #
Super Moderator
1. On the phone, press "contacts" and highlight the entry you wish to transfer. Press the "Options" key and scroll down and press "Share Phonebook Entry". It will show you all of the bluetooth devices that the phone knows. Select the one for the car, but don't press it yet.
2. On the car, press "transfer", select the group, and then press "add to". It will tell you to start the transfer.
3. Now, back at the phone, go ahead and press that bluetooth name. You should then see a status screen (on the phone) as it transfers the contact to the car.
4. A few seconds later, the car should say "transfer completed" and you are done with that entry.
Note:
a. If you have your phonebook (on the phone) set up in "view primary contacts" mode, and you have multiple phone numbers with the same contact name, all numbers for that contact will be transferred at once.
I also have the VC3. But I have the firmware before they disabled the Obex. (I can transfer to/from my laptop w/ BT). However there is not "transfer" option on the phone menu. Anyway I can get these phone numbers into my car without typing them again?
Thanks
Thanks
Super Moderator
Thanks
Thanks
yea, like everyone else said you can only transfer one at a time.
lucky for me I have an unlocked Sony Ericsson w810i and I was able to transfer my entire phonebook at once
I did this the 1st day I had the car....it was a piece of cake!
