Trunk Light?
Originally Posted by Taka
do you know what bulb type they are? 194?
[update]
just checked myself. they are not 194..
[update]
Originally Posted by vApor21
I was planning to change these dome lights as it is the same one for the door lights that lit up when you open the door, I just havent got the chance to measure the length of the dome light which could be 1.25 in or 1.5 in.
well after you measure it out.. tell us. it seems like the Xenon Super White Festoon Dome Light Bulbs will look the best. (the last one on http://autolumination.com/festoon.htm) only $1.50. pretty cheap
On the replacement bulbs, the stock light does appear pretty weak--has anyone ordered a replacement. Based on the cross-reference chart, it looks like the 3022 , 1.25 inch (31MM) is the correct bulb size. Which one should throw off the most light, the 6 LED, the Xenon or something else?
Originally Posted by lifeisgood
It took me five months to figure out that the car actually had a trunk light. I never expected that the trunk light would have a switch, and that the car would be delivered with the switch turned off. I simply thought that Lexus was cheaping out and only offering the trunk light on cars with the Luxury package--but then I thought why did they provide puddle lamps on my car but no trunk light. So I did a search and learned something new. Thanks guys.
However I was able to fit 36mm in there. (I dont recommend this size though).
Festoon Dome 36mm 6 LED (Xenon White) Bulb
2nd pic
Originally Posted by Payam
I thought I didn't have one either, but believe it or not it's back there. open your trunk and stick your head inside and look straight up, there is a light up there with a toggle switch on it.
Originally Posted by Tuxlex
Yes it does turn off when you close the trunk lid all the way.
If you want to convice yourself, you can leave the trunk
pass-thru open and check by looking from inside the car.
No need to get inside the trunk to do this - hehe
IM emailing this from my blackberry, i got stuck inside my trunk to check for this.......im just waiting for the police to show up..
J/K
yeah, i felt dumb too..........
