Trunk Light?
I thought I didn't have one either, but believe it or not it's back there. open your trunk and stick your head inside and look straight up, there is a light up there with a toggle switch on it.
Originally Posted by FlyGrl IS
You're KIDDING me! All this time and I'm just assuming no trunk light?! Geeze, do I feel like a dope! Thanks so much for the info!
Yes it does turn off when you close the trunk lid all the way.
If you want to convice yourself, you can leave the trunk
pass-thru open and check by looking from inside the car.
No need to get inside the trunk to do this - hehe
Originally Posted by FastGirl
Are you really sure about that trunk light staying on?
Originally Posted by dmanbluesf
You could always get in, close the trunk and find out.... then just use the little quick saftey release to get out ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Originally Posted by vApor21
well the trunk light is soo dim that its the same as if there was none.. wonder if we can change the bulb to make it brighter.
