requesting detailed foglight removal diy
can the next person thats changing their foglights PLEASE make a detailed DIY with picures?? i think many people including myself will greatly appreciate it. Ive already looked at posts that explain the directions in removing them, but i still havent been able to do so. thanks.
thanks.. i tried doing the drivers side.. and had trouble pulling out the plastic well cover thing.. i took out the two screws on the side and the one screw on the bottom.
I don't have any pics, but it's really not that hard.
The hard part is just being willing to pull the plastic cover back. After removing the two plastic screws/tab and the screw towards the bottom middle you just have to pry and bend the plastic back. I know it's scary doing this on a new car but the plastic is pretty bendable and will go back in place once you're done. I just did mine the other weekend.
check out this thread. https://www.clublexus.com/forums/sho...ight=fog+light
after i removed the screws i just stock a flat head screwdriver in b/w the liner and fender to pry it out a little and then grabbed it with my hand and pulled the fender liner back slowly.
Organized Garage Status
03-14-18 10:53 AM
