what's the best way to launch this car?
Okay I know most people know that doing the pedal dance is probably the best thing to do but what about the times that you just don't have the opportunity? What's the best way to lauch the car? Turning on ECT Power mode and turning off the TRAC and break torque a little? I'm thinking this is probably the next best thing to do. I'm wondering if turning trac mode off will try to bog something down when it kicks back in at 30mph. Anyone have any experience with what's the best combo or method? Thanks!
11 Second Club
Originally Posted by Shinobi-X
If I'm understanding you, when you take traction control off, it comes back on at 30mph?
Originally Posted by caymandive
Yeah but that traction control button is useless. Even before 30mph the traction control kicks on even with the button pressed. If you want actual traction control removed you have to do the foot dance when you 1st start the car up.
11 Second Club
Originally Posted by ba-b4
Really?! Then what's the button used for? Or what does it do actually? I thought it allowed the tires to spin a bit before traction control kicks in later so I was thinking that this'll give a better launch?
^ okay so it still does let the tires spin a little. I guess that's enough to break the traction a bit to get a better launch instead of bogging that is assuming it doesn't cut off some of the power, but I'm just wondering if by turning trac on if the computer does lower the power a bit because it was meant to get the car out of snow or a slippery surface right? Someone must have done a timed run already with and without trac on.
I believe some canadian guy that was busting out 104mph trap speeds in the low 13's was just using the car in pwr mode. Didn't disable anything and I believe he power braked a bit.
Originally Posted by conekiller
I would be VERY surprised to see 104 traps and low 13s from a stock 350. It might be possible to do better than the manufacturer's 14.2 seconds, but 14.2 to low 13s is a LONG way off. I'll believe it when I see it.
11 Second Club
https://www.clublexus.com/forums/sho...7&page=1&pp=15
What works for me
* ECT in PWR mode
* Manual mode, select 1st gear then back up to second, before the launch
* No power braking, just floor it
Here's why I select 1st then 2nd gear before starting:
* selecting 1st puts the trans in 1st gear (logical...)
* then selecting second allows me to lift the foot a little IF wheelspin starts (usually above 4,000 rpms) and then the trans immediately switches to second gear. I then floor it for the rest of second all the way to redline. Then redline through all the gears after that.
Why no power braking: causes immediate wheelspin.
Is it the optimal way to launch: dunno. Does it work: I've sent 350Z drivers home crying for their mamas doing it this way!
11 Second Club
Originally Posted by cdeslandes
* ECT in PWR mode
