how to lock the trunk?
I have read the manual several times, thank you.
I want to be able to leave the trunk LOCKED all of the time so that it can NOT be opened with the small button under the trunk lid. In order to do this, I have to leave the button in the glove box in the OUT or LOCKED position. But, then I cannot open the trunk with my remote or with the button under the driver's side of the dash.
If I leave the button in the glove box in the IN or UNLOCKED position, then, even with the car locked and the security system armed, the trunk can be opened with the small button under the trunk lid.
Am I missing something? Someone please explain. And, if I missed this in the owner's manual, please give me a page number as I have not been able to find it on my own.
Are you saying that the trunk can be open with the small botton under the trunk lid EVEN if the key is not in the area. You might opening the trunk with the key in your pocket hence allowing the trunk to be open.
so you don't have to take your key fob out everytime you want to open the trunk. If the key fob is detected then the rubber switch will be active. On the other side of the chrome sash you will find the hidden key slot for the metal backup key in case there was a battery problem you can manually open the trunk. In your Lexus personalized settings you can vary the amount of time or number of times you could push the trunk release button on the fob. Choices are no delay, .8 seconds delay (standard), press two times to release the trunk, and the last choice you can make is to make the fob button unable to release the trunk but it's not popular...
Rock
Rock
Duh! That was one possiblity that I did not think about. And, I did not see mention of it in the Owner's Manual.
Now, I'll go back to leaving my briefcase in my trunk, at times, where it is out of sight.
