LMS vs. Fujita 5 Intakes
Anyone know the diameter of the flange on the air filter with the LMS intake kit? I know that fujita's is 3.5 inches -- is this also the case with the LMS?
Also, any idea on what an LMS kit will run me?
Sorry if this is slightly off-topic but someone should just make a plastic (same material as the OEM) tube shaped like the joe z and sell it for $80. You won't have the heatsoak issues with metal and it'll be lighter (not by much but every bit helps especially in the front of the car.) You could also use the OEM clamps. Tooling up might be somewhat expensive but after that, you probably have $2-3 in materials.
I may be slightly off topic as well, but, the Japanese are such masters at maximizing efficiency, I don't understand the design of the stock intake pipe with the ribbed outpouchings. Secondly, what is the horshoe shaped thing on the side? Both of these would seemingly produce great amounts of turbulence, but, I am no engineer. Would the ribs somehow eliminate the slower moving air along the wall of the intake and by some stretch of the imagination, improve the flow centrally? Seems easier just to make a smooth pipe - I ordered the Joe Z, myself. Any engineers want to chime in on this one?
Originally Posted by casey225
I may be slightly off topic as well, but, the Japanese are such masters at maximizing efficiency, I don't understand the design of the stock intake pipe with the ribbed outpouchings. Secondly, what is the horshoe shaped thing on the side? Both of these would seemingly produce great amounts of turbulence, but, I am no engineer. Would the ribs somehow eliminate the slower moving air along the wall of the intake and by some stretch of the imagination, improve the flow centrally? Seems easier just to make a smooth pipe - I ordered the Joe Z, myself. Any engineers want to chime in on this one? ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I haven't considered the JOE Z because it uses the stock air box. I like the look of the cone filters and also the "growl" that the open filter gives the engine.
Any difference in the addition power made between the fujita and LMS?
Both the fujita and LMS are a total waste of money IMO. Terrible design and does not give you any power, just the opposite. If you feel 306HP is simply too much and the car needs to be louder, then i'd recommend it.
Originally Posted by 4TehNguyen
resonator to make the intake quieter, and yes the ribs slow the intake charge, caymandive dynoed his joez intake and it gained 7whp throughout. Most of the gains were at higher rpms which makes sense, as the ribs would slow high rpm air flow
LMS DYNO:
![](https://www.clublexus.com/forums/attachments/performance/79972-lms-intake-dynograph-vs-basline-dynograph-sae-dyno-with-lms-intake-small-.jpg)
JOE Z DYNO:
![](http://www.coleplay.net/photos/JOEZ%20Dyno.jpg)
I'm not trying to burst your bubble and I definitely appreciate your time/$/effort in bringing this info to the board, but because you took the dynos several months apart, it could be that the car is just continuing to break in. For the best accuracy, someone is going to have to try both tubes on the same day and conditions, if possible.
the stock intake is more of a cold air intake than the LMS Fujita intakes are (taking engine bay air), which is what you want for the most gain.
JoeZ and a K&N drop in filter would be close to what a true cold air intake would be, without the hacking of metal like you have to do to install some CAIs
