View Poll Results: What information do you leave the screen on?
Blank
0.68%
Outside temp
128
43.54%
Avg speed
0.68%
Avg MPG
13
4.42%
Tank Avg MPG
37
12.59%
Current MPG
21
7.14%
Tank Range
21
7.14%
Gear Position
70
23.81%
Voters: 294. You may not vote on this poll
What do you leave the multi info display screen on?
#31
Originally Posted by gshb
can people tell me why they have the LCD set to the outside temp? i just dont understand how knowing the outside temperature is useful information...i have mine set on the current gear almost all the time. when im running out of gas i set it to miles left in range.
#32
Honestly I wish there was a feature like some other cars to let you set it to rotate every like 5 or so seconds to the next screen. Gear position isnt useful when ur going down the highway for 60 miles... your not going down from 6th gear all too much. The outside temp I also find useless, but others love it.
#34
Super Moderator
Originally Posted by diablo1
Sometimes I feel like it is hard to get a very accurate readout from the spedometer, since the numbers are so close together. I guess that's what happens when your spedometer goes up to 160.
The ideal place for a digital speed readout would be the navi. The GPS would allow computation of an extremely accurate speed reading, unaffected by things like wheel and tire size.
#35
#37
Originally Posted by Bichon
It's always hard to get an accurate reading from the speedometer, because the speedometer isn't accurate. Mine reads about 3-4 MPH fast even at 40 MPH.
#38
I have mine set mostly to miles left in tank because I'm horrible at filling up when I'm low on gas. I have driven my car til there was 1 mile left before but I know that's just to scare me because there's usually a reserve of at least 2 gallons left.
Anyway, I have a question about the outside temp display. Is it just me or is the thing not accurate? Like it'll say outside temp is 77 degrees when it actually feels more like 85. Is the computer accurate or my own estimation of what it feels like is wrong?
#40
Super Moderator
So you're saying that when you think you're going 40, you're actually going more like 36-37? That is interesting...
Could the GPS really be used to track speed information that reliably? Wouldn't it be like the nav map, updating say once a second or so? You wouldn't get the smooth needle movements like you do for a spedo linked to the tires. In any case, it seems like it would be harder to get a reliable speed reading from a satellite than from the car's own rotating tires/axles.
#41
You are correct - the GPS display would update less frequently, but be more accurate. That's why I'd drive the speedo needle from the wheels/axles, but offer a separate digital speed readout from the navi.
As for all the "termperature gauge" haters... Temperature may be pretty useless, but so is most everything else on that display, except maybe tank range, which is still pretty approximate, and only really useful when your tank is low. Instantaneous MPG display? I'm sure that's not accurate. Gear display? Only really useful if you're paddle shifting. Most automatic cars don't display it at all. Thus, out of all the fairly useless information, I find temperature to be the least useless.
#42
#43
#44
