View Poll Results: What information do you leave the screen on?
Blank
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0.68%
Outside temp
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
128
43.54%
Avg speed
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0.68%
Avg MPG
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
13
4.42%
Tank Avg MPG
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
37
12.59%
Current MPG
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
21
7.14%
Tank Range
21
7.14%
Gear Position
70
23.81%
Voters: 294. You may not vote on this poll
What do you leave the multi info display screen on?
#46
I don't know about your IS, but when I put mine in S mode, it automatically switches the display to the gear position. No fiddling with buttons is necessary.
#47
#48
My mistake, I was thinking of the gear SELECTER display, not the gear POSITION display.
I can see how gear position would be helpful in S mode, I never really thought of it much though, I generally do my manual shifting based on RPM.
#49
#50
Originally Posted by mikewpu04
I use gear position for the simple fact that even when in S, the car does sometimes downshift on you even though your gear window says something diffrent. Annoys me but hey, it is an automatic
I've noticed that even when its in gear position it says 6th. I can see / feel the car like downshift for a brief moment and i can see the rev needle go up but the gear selection stays in 6th.
#51
Anyone else notice that?
#52
Mine doesn't do that at all. I usually make sure I'm in gear position first. I can't use S mode without it. I guess ur car is cooler then mine ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
#53
Originally Posted by danis
When in S mode a numeric gear display, apart from the multi-display, appears and gives the gear position. Now I admit that the numeric display gear position, which I assume is the correct gear, does not always agree with the multi-display gear position. ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
The display that comes up automatically, which the small numeric display located between the spedo and tach, shows the gear setting that you have selected with the paddles or the shift ****. This only comes up when "S" or "auto-manual" mode is selected.
The display that you can select from the multi-info LCD shows the gear that is actually engaged.
The difference is that when you "manually" select a gear, you are selecting the highest gear you want the transmission to use. For example, when you select "3", the tranny will choose either gear 1, 2, or 3. It will automatically downshift when you stop at a red light, for example. The display that shows the selected gear displays automatically. The display that shows the actual gear engaged must be seleced with the DISP button on the steering wheel.
Hope that helps!
#54
What I would have prefered was that the highest gear selection automatically updates and follows the actual gear the car is in AND also drops the "highest gear the car is allowed to go into" down. Basically downshifts and stays there… wont upshift again till you command it to.
#56
Originally Posted by diablo1
I think I might know what the confusion is with the gear display automatically coming up or not. There are two gear displays, which provide slightly different information:
Hope that helps!
Hope that helps!
And the other annoying thing a little OT...why does it always start in 4th!
