Jerking and pulling
Jerking and pulling
Got a bad problem. When I am sitting at a light, and just idling, the car seems to jerk forward, and kinda pull. Any ideas what that might be, and does anyone think that it might have something to do with my intake????? Hope not.
OK, this is gonna sound stupid but mine did the same thing for about the first 5 months. Then one day I noticed a strange coincidence when the car wanted to jerk when I was stpped. My big *** size 14 foot was on the gas slightly. Seriously. The engine is so quiet I never noticed until then that I always had car revved to about 1100 at stops by slightly being on the accelerator. The car normally idles around 750.
I know my foot isn't on the gas. I sit and watch the rpms, and they jump a bit, and my foot isn't anywhere close to the accerator. I hope it isn't an electrical problem, cause the other morning I went out and my windows were a 1/4 of the way down, and then it happened again a few nights after. It stays in my garage, and no one has a key but me. And i always make sure that my car is secured and locked with all windows up before i go to bed at night.
explain what you mean by drive-by-wire
drive-by-wire = throttle is controlled electronically, usually by a potentiometer wired to the accelerator pedal which sends an electrical signal to the throttle body, rather than the old tried-and-true method of using what is essentially a cable not unlike a bicycle brake cable to open and close the throttle body. On newer Audis, DBW uses lots of guesswork for throttle input...pressing the accelerator halfway down = wide open throttle body input. Put simply, pressing the pedal halfway down is the same as pressing it 3/4 or even mashing the pedal against the floorboard. It makes it more difficult to modulate how much throttle input you actually want at any given time. At least with the old cable throttle car makers used to put in vehicles you had an infinite amount of throttle input to use, depending on how far you put your right foot down. Most new cars use DBW now and it wouldn't surprise me if the Lexus version uses some of the same stupidity prevalent in Audis and other cars.
I seriously doubt your intake has anything to do with it. I'd just take the car to the dealer to have it checked out, but take your intake off so they cant blame your intake.
Liquid Bra Champion
Not really. I put the intake on 3 days after I got the car, and it just recently started doing all of this ****. So I don't think its the intake.???
Did you by any chance e-shift the car into first gear at last moment. Cause sometimes I find it jerks when I shift the gear down to first just before the car stops. Then when it stopped it felt like it jerked a little, I dunno.
Might want to check all the vacuum lines around the intake and make sure none of them worked their way loose.
I too find throttle-by-wire a bit cumbersome and unnecessary... Kind like reinventing the wheel.
