Ash tray Mod?
Thanks Clubfoot for posting the pictures. Your shots are much more useful than the small picture on the L-Tuned website.
I noticed you removed the entire console cover. Is that a necessary step in the installation? If so, how hard/easy was it to do?
Many thanks!!
Many thanks!!
Super Moderator
Originally Posted by skorpio
Wait a minute! Is your wood painted on?? I thought it should be a real wood! Ill have to check my car again... Ill be really pissed if its not!
regards, Bart.
regards, Bart.
Originally Posted by larsdenner
What happens to the power outlet? I use mine to charge my phone and I put my sunglasses in the overhead compartment.
I have NOT been able to locate a "little lever" hence I have not been able to remove the ash tray in my 250AWD. Where is it? A picture would help, but I will settle for a clear description.
Super Moderator
Originally Posted by jasoncd
Can your charger use the power outlet in the arm rest?
Years ago I hid the controller to a CD changer in a compartment similar to the IS'. Fabricated a plate to mount it and then the door would close over the controller so no one could tell it was custom. Good thing I don't smoke.
Kinda tight. It's a shame the power outlet wasn't 90 degrees in the arm rest so it can be closed while in use. .
Did you ever do this?
I have plans for that tray. I need a place to mount either a computer screen for my future car computer or build a dock connector for my ipod. I could probably make due with what I already had but this new tray might provide a cleaner solution. This is my $1,000 summer car computer project, the tray came out of the budgeted amount.
You likely already have a "coin holder" in the dash on the left side behind the steering wheel. You can get more of those plug-ins from ebay. Mine came with one.
