Are cheap HID kits a bad idea even for fogs?
So I want yellow fogs.
Questions is do I go with a cheap HID 9006 kit or go with some PIAA yellows, or some even cheaper yellows.
This is more for looks, since the car can't do foglights alone. I do some driving in fog, but probably no more than 10-15 times a year.
I'm leaning towards a chaper (think 150-200 non phillips) HID kit at this point, as I think the look and the output will be far superior especially considering spendding 65 bucks on PIAAs will keep me happy.
So is there really any reason to go with a "high quality' -i.e;phillips)" HID kit for yellow fogs?
Or is there such little difference that cheap bulbs would be the way to go.
Cheaper HID kits might give you a little less light output than maybe a Phillips kit but it will still be night and day with what you have in there now. And really the only down fall to using a cheaper kit is that it might burn out quicker than a better kit.
Well good at least someone has sort of the same opinion as me. LOL!
I gotta imagine its safe to say a cheap HID kit will far out lightbling an expensive halogen, especially in the yellow dept.
FWIW, you're going to have a much shorter bulb life than with your main headlight HID's with fogs, if you plan on switching them on/off on a constant basis. This is why separate-bulb high-beam HID's are a bad idea.
If you leave them on for as long as you leave the headlights on, it should be okay.
Just giving the heads up.
On Ebay the cheapest I could find a 9006 HID 3000k kit was 180 shipped, where as the phillips/mculloch reputable type products will cost close to and above 400+shipped. And all sorts of kits in between.
I'd be leaving my fogs on pretty much all the time the headlights are on. I thin I'm going to go the cheap route on the fogs and see what happens. It will either be a 200 dollar lesson, or a slightly more expensive alternate to yellow halogens.
me and my friend has bought a few $200 level kits
most of them have some problems, usually the connection problems.
some takes a while to light up, meaning it flickers when u first switch it on.
i even bought a kit that claims to have mculloch bulbs,
but the light output wasn't close to the same mculloch kit that i have.
i would say stay with mculloch,it's not more than $300 shipped
and i have no problems with it, three kits so far.2 dating more than two years.
