hid help
I just got my hid installed. Its a 6000K kit.
anyway, the headlights don't look as bright as I thought they should be.
also, there are a lot of stray lights...it looks like two "u" shaped lights in front.
I wonder if it an alignment issue. so my question to you guys who have had them installed, did you have to do any alignment? if so, how do i do that.
When you get tired of the looks you can always buy just the HID bulb 4300k is the best output
Check the Bulb. It might not be sitting properly on the projector.
6000K is very bright. I think maybe your bulb is not fit correctly.
https://www.clublexus.com/forums/sho...highlight=MTEC
if you have the stock 4300k HID headlamps . . . what all do you need to convert to the 6000k? Just bulbs? I tried looking on xenondepot.com and cant seem to find what i might need.
The bulb is not sitting right. I found that most aftermarket kits, the rubber O-ring is too big and the bulb does not sit right. What I did is swap the O-ring from the original halogen bulbs, once I did that, the HID bulbs went in without a prob.
Try that, but from your description, the bulb is not seated right.
Someone correct me if im wrong but you need to look for D4S 6000k HID Bulb.
Try Ebay.
Goodluck
villan
03-01-11 12:52 AM
