For HID's, I'd need to get H11, correct?
Originally Posted by vicestan
When hid bulbs go out ( and that will be about 4 years for oem bulbs ) you just replace the bulbs. And the 06 lexus models equipped with HID all use d4s bulbs. Prepare to sacrifice alot of visibility when moving up in kelvin temperature especially when using aftermarket bulbs they tend to put less Lumins when compared to oem bulbs running at the same temperature. PS good luck finding 6000k+ bulbs with a d4s base. I doubt they will be out in the near future.
Prepare to sacrifice alot of visibility when moving up in kelvin temperature especially when using aftermarket bulbs they tend to put less Lumins when compared to oem.
When going from the stock 4300K to 6000K, do you loose a lot of visibility?
all of this 4300k vs 6000k is useless, let me tell you, i had 4300k on my last car and now on my is i have 6000k and i can tell you no matter what, the light output is still great, that 20 percent will not be noticeable. well, maybe alittle bit when it rains but other wise your still good to go. if your debating on which Kelvin rating you should get, do what you want, pure white with little better visibility or little bit of color added with alittle less visibility. regardless you will no go wrong. sure beats halogens thats for sure.
mstrsltr
GX - 1st Gen (2003-2009)
14
01-25-17 07:58 AM
Caboose
10-31-08 08:14 PM
