For HID's, I'd need to get H11, correct?
what if i have the stock 4300k HIDs but want to switch to 6000k . . . what all do i need? I tried searching but everyone is using halogens then using the conversion kit. . . is this what i need too or do i just need the bulbs? I would like to get a nice kit . . . philips or whatever from xenondepot.com.
you would just need to get the actual H11 bulbs only, no need to get a kit.
Originally Posted by Reyngel
Thanks. Any recommendations for a good, easy to install set? And do all sets require you to drill a hole into the dust cover?
The kit I put on my IS is the MTEC 6000k H11 kit. got it on ebay for a great price.
Originally Posted by PNice972
yes, you will have to drill a hole on the dust cover, there really isnt a way around it, unless you want to risk condensation in the housing.
The kit I put on my IS is the MTEC 6000k H11 kit. got it on ebay for a great price.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
https://www.clublexus.com/forums/sho...highlight=MTEC
Also, how long have you guys had the MTEC kit on? Any problems? I've read that the 6000k kit isn't as bright as the 4300k kit. How much brighter, percentage wise, is the 6000k kit when compared to the stock halogens?
https://www.clublexus.com/forums/lighting/84611-4300k-vs-6000k.html
had my mtecs for a month and they work great.
When hid bulbs go out ( and that will be about 4 years for oem bulbs ) you just replace the bulbs. And the 06 lexus models equipped with HID all use d4s bulbs. Prepare to sacrifice alot of visibility when moving up in kelvin temperature especially when using aftermarket bulbs they tend to put less Lumins when compared to oem bulbs running at the same temperature. PS good luck finding 6000k+ bulbs with a d4s base. I doubt they will be out in the near future.
